70 4speed setup into 67 Cutlass ?
Old Feb 10, 2014 | 07:48 PM
squirell's Avatar
Govt slave
Hi guys,
I just received from a friend , out of his 1970 442 ....the 4 speed pedal setup ,linkage ,shifter,z-bar,flywheel ,clutch and bellhousing.
Basicly everything except the trans.
I want to convert my 1967 Cutlass to a stick.
The question is :
Is the 1970 setup the same as 67 ?
Old Feb 10, 2014 | 07:55 PM
66400's Avatar
Clutch, bellhousing same. Shifter will work but not correct for 67. Pedals linkage flywheel not the same. You'll need a 64-67 flywheel from a 330/400/425 car.
Henry
Old Feb 10, 2014 | 08:18 PM
squirell's Avatar
Govt slave
Henry
Thanks Henry,
I forgot to mention I have a 70 455 in my 67 Cutlass.
So pedals and linkage only then ?
What about the ball that goes on the Block for the z-bar ?
The engine was/is from an automatic
Old Feb 10, 2014 | 08:28 PM
66400's Avatar
Flywheel will work seeing you have a 455 in place. Ball stud is ok. Pedals not the same maybe you can modify them? Don't forget the crankshaft issue on an automatic engine.
Old Feb 10, 2014 | 08:35 PM
squirell's Avatar
Govt slave
what's the crank issue ?
Old Feb 10, 2014 | 09:08 PM
oldsmobiledave's Avatar
Fyi
Most Olds 455 cranks are not drilled for the input shaft.
Old Feb 11, 2014 | 09:10 AM
The 64-67 cars use completely different pedals and equalizer from the 68-72 cars. Also, the frame-side bracket for the equalizer is bolted onto the 68-72 cars but welded on the 64-67 cars. A repro bracket is available, but you'll need to weld it into place.
88hurstolds
Aug 20, 2013 11:22 AM
StickW31
Oct 22, 2010 08:47 AM
fatboy578
Oct 21, 2008 11:13 AM
z11375ss
Oct 18, 2008 07:35 PM
