455/200r-4?
Old Sep 8, 2014 | 01:07 PM
RustRocket's Avatar
455/200r-4?
Just a quick inquiry, but will a 200R-4 bolt to a 455? The previous owner of my Cutlass has a 455R from a 1969 Toronado, as well as a "built" TH-400. I can't stand 3-Speeds, so I was wondering about a 4-Speed that bolts to a 455 Rocket. I only know of the TH-400 and the Borg-Warner Super T10(manual). I heard the 200R-4 would bolt up, is this true? I'm just looking for suggestions
Old Sep 8, 2014 | 01:18 PM
70cutty's Avatar
Beer Connoisseur
It will bolt up to 455 with no problems. How long will it last is the question.
They can be built to stand up to a fair amount of abuse, but in stock form it will not last too long behind even a stock 455.
check out http://www.ckperformance.com/resourc...SMISSIONS.html, that's just one of the vendors out there that make their own parts and build 200r-4.
Old Sep 8, 2014 | 03:51 PM
Redog's Avatar
Yes it will bolt up, but if you want to do a 200R4 for now, and then save up for the other CK trans later, you can, just get one from a Monte Carlo SS or Grand National. The GN trans is the strongest 200R4 you can buy in stock forum
Old Sep 8, 2014 | 03:52 PM
ALL Oldsmobile V8 motors from 1964-1990 have EXACTLY the same bellhousing bolt pattern (with the usual exception of the 1964 394 motors). Any trans that bolts to one of them bolts to all of them.
Old Sep 30, 2014 | 06:20 PM
Charly9g's Avatar
Aren't there 2 versions (bell housing size) of the 2004R?
Old Sep 30, 2014 | 07:14 PM
oldsmobiledave's Avatar
455r ????
What is a 455R?
Old Sep 30, 2014 | 07:58 PM
70cutty's Avatar
Beer Connoisseur
455 with VTEC
Old Oct 1, 2014 | 05:50 AM
Professur's Avatar
Nope. There's only one, but it has both the SBC and BOP patterns on it.
Old Oct 1, 2014 | 05:55 PM
TexasT's Avatar
Three different configurations. As above there is a dual bolt pattern and this is the most common. There is also a bop only and a Chevy only. The latter two aren't near as common, but it is something to be aware of.
Dual Bolt Pattern
BOP only pattern
Chevy Only
Old Oct 4, 2014 | 02:34 PM
RustRocket's Avatar
Originally Posted by oldsmobiledave
What is a 455R?
455 Rocket, just my shortened terminology
Old Oct 4, 2014 | 07:02 PM
455r
Ok. This is an Olds site so I doubt anyone would have assumed that a 455 was anything but an Olds but if you feel the need to call it a 455R then so be it.
Old Oct 5, 2014 | 09:48 AM
That's a little confusing. GM used the letter "R" in the VIN in the late 1970s to designate the Olds 350, so some auto parts catalogs will refer to the "350R" for this reason. The 455 motors were designated by different letters and listings will often refer to those.
dp442
Feb 15, 2011 04:22 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
egknz
Jul 21, 2009 01:09 PM
