Turbo 400 brackets
Turbo 400 brackets
Guys:
I need the cable mount bracket that bolts to the pan and the bracket that bolts to the selector shaft for a Turbo 400 in a 69 Cutlass floor shift setup. I would rather use OEM than repop items, could also use an OEM cable as well. You guys
have been a great help so far in this project.
Thanks Ron 614-309-1513
I have a 1972 Oldsmobile Cutlass S that came with a 350/350 turbo trans. I have replaced the motor and transmission with a 1969 455/400 turbo long tail transmission. I have found that the shift cable bracket from the turbo 350 will not reach the bolts in order to mount the bracket. Can anyone help me and let me know what I will need??? Thanks... 706-851-7053 Dave
