Hello all! Question. 350 Turbo to 400 Turbo
Old Feb 26, 2012 | 07:25 AM
matviar's Avatar
I just purchased a OG code Turbo 400 for my 455 conversion. My 1970 Cutlass originally came with 350 engine and TH350 tranny. The 400 Turbo I bought did not include the torque converter. I'm dumber than a rock when it comes to transmissions, stall speed and all of that stuff. Can I use my 350 TH converter in this TH400 and would I loose any benefits of performance? Any insight would be appreciated! Rick
Old Feb 26, 2012 | 08:24 AM
Yes, the converter will work on either trans. The stall speed is a different issue. It is usually based on cam size, gear ratio, and what your trying to accomplish with your setup.
If your T350 grenaded and you contaminated the fluid I would not use that torque conv on the new trans without first getting it cleaned up.
This will sound worse than it actually is:
Also, you will need to move the transmission cross member back approx 6", so your drive shaft will not work with the T400 as well as the yoke. The relocation of the cross member will result in a mod to your e-brake cable. You will need a kick down switch and harness as the passing gear works off a switch versus the T350 cables.
Old Feb 26, 2012 | 08:40 AM
matviar's Avatar
Thanks! I bought a new yoke. Someone earlier mentioned I could modify(shorten the cable hangers so the E brake cables dont droop. I noticed the frame has extra holes behind the crossmember, so I guess I must move the crossmember back to these holes? I will have my drivshaft shortened and re-balanced. I need to find out to what the driveshaft length is on a 442 car. Did I cover everything?
Old Feb 26, 2012 | 09:55 AM
The best (and easiest) way to deal with the cables is to simply buy the front and intermediate e-brake cables for a TH400-equipped car. Be sure to get the intermediate cable for your wheelbase (112" for the 2DR cars). The factory used different parts for a reason.
Old Feb 26, 2012 | 10:25 AM
Someone earlier mentioned I could modify(shorten the cable hangers so the E brake cables dont droop. I noticed the frame has extra holes behind the cross member, so I guess I must move the cross member back to these holes? I will have my drivshaft shortened and re-balanced. I need to find out to what the drive shaft length is on a 442 car. Did I cover everything?
That was me on the e-brake. I just fab'd a shorter hook to replace the one on the cross member. Move the cross member towards the rear of the car and it will bolt up to existing holes.
I had a new drive shaft made as it was the same price as modifying the old one. My 45 year old drive shaft was the 2 piece with a rubber sleeve. I felt that it would not be strong enough to handle my power train.
It's a fairly easy swap. I used a 2400 - 2600 stall for my converter with a big block.
http://www.tciauto.com/tc/th350-th40...ing-plate.html
Old Feb 26, 2012 | 11:05 AM
Rickman48's Avatar
You'll also need a kick-down switch for a T-400, unless you like 'pulling' gears!
And the appropriate hook-ups.
80_cutlass
Mar 17, 2011 06:03 PM
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
RPD1659
May 18, 2008 07:19 PM
