Add speedo gear drive to a Delta trans
Old Apr 21, 2014 | 05:37 PM
Uncle Hulka's Avatar
Ancient Olds Lover
How do I add the speedo gear drive to a Delta trans?
I'm installing a TH400 from a 1969 Delta into a 1969 Cutlass S. I know I will have to have the drive shaft shortened, as this is a medium-tail trans. However I just realized this trans does not have a provision to connect the speedometer cable to the transmission. Where the speedo gear should be is a freeze plug. I read a thread where Joe Padavano said these transmissions can be easily converted to add the speedo gear.
Bottom line; can anyone here outline how to perform this modification?
I appreciate any help. Thanks!
Uncle Hulka
tmaleck
Sep 23, 2013 01:47 PM
sbFALL63
Nov 18, 2012 10:51 AM
66-3X2 442
Sep 26, 2012 04:50 PM
racing8up
Jan 21, 2010 02:27 AM
Redog
Jul 26, 2007 02:30 PM
