PDA
View Full Version : Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13]
  1. Torque converter capacity
  2. transmission modulator valve
  3. Transmission options for 66 cutlass
  4. 63 tranny slimjim?
  5. 63 slim jim shift prob?
  6. help I.D my th350
  7. lock up converter
  8. Th400 Yokes
  9. 3 Speed hydramatic 1963 F85 Driven gear
  10. 47 Coupe New to the site.
  11. torque specs
  12. 1967 Jetaway "Clunks" on downshift
  13. shift linkage 70 W31
  14. problems....
  15. to flush transmission or not to flush?
  16. TH 350 and TH 350C lockup question
  17. th400 tranny HELP
  18. 1935 3 speed to 4 speed swap. HELP!
  19. Saginaw, Muncie, T 10
  20. need a rebuilt 200 4r
  21. turbo 350 problem
  22. A lot of Questions with many different parts
  23. 87 cutlass with trans trouble
  24. 350 transmission
  25. 66 Delta 88 - What tranny was stock?
  26. Manual trans in a G-body.
  27. transmission shift
  28. Best way to flush an automatic transmission?
  29. Transmission identification numbers...
  30. OG transmission tag
  31. Toronado Transmission Question
  32. th 400 questions
  33. Th400 tailshafts
  34. 4 speed auto behind a 403 what to use??
  35. Conveter bolts?
  36. Kickdown ?
  37. Need help with my carb swap... QUICK
  38. Stratoflight
  39. HYDRAMATIC PROBLEMS! HELP!
  40. Which convertor should I get?
  41. TH2004R into 68 cutlass 455
  42. 3-speed conversion: column to floor
  43. Jetaway swap?
  44. Vacuum line 1972 Cutlass
  45. 69 TH350 Shift Kit
  46. 1975 Cutlass 350 4bb
  47. 55 tranny picture?
  48. Floor shifter Question
  49. 1961 Hydromatic
  50. Stall converter?
  51. leaky pan gasket
  52. clearance between slip yoke, and tailshaft question
  53. Hydo
  54. 67 cutlass 330 kickdown switch
  55. 66 delta 88 transmission
  56. What is this for?
  57. Oldsmobile & Chevrolet Transmisson
  58. toro tranny probs
  59. auto column to floor shift, please help
  60. TURBO 400 TRANSMISSION HOUSING
  61. SWITCH PITCH CONVERTER
  62. Rebuild Dual Hydramatic or convert to TH350
  63. Bad Tranny or what/ TH350?
  64. I need help from a TubroHydromatic Pro
  65. TH400 vs. 200 4R vs. 700 R4
  66. th 400 front seal leak
  67. Jetaway or Turbo Hydromatic ?????
  68. slim jim replacement
  69. leak around the linkage
  70. attaching 69 cutlass console
  71. Tranny backing a 455
  72. 1947 hydromatic help
  73. jetway tranny..to junk or not to junk
  74. 49 hydramatic shift problem
  75. converter question
  76. th350 kickdown and electronic?
  77. WANTED: Flexplate inspection Shield
  78. Converting '53 Olds 3 speed manual column shift to floor shift?
  79. Manual Conversion
  80. TH350 versus TH400?
  81. can't find source of leak
  82. 455 manual trans
  83. 69 automatic console plate
  84. TH 350 Installation
  85. tranny oil
  86. TH 400 tranny vacuum line
  87. D'oh and Who-Hoo in one breath
  88. 1966 Transmission, positraction, gear ratio
  89. TH 350 tranny speedo hook up
  90. what can a TH350 handle?
  91. th425 low miles whats it worth
  92. engine/tranny swap
  93. jetway 2speed to a th 400?
  94. 1994 Cutlass Siera Transmission
  95. Overdrive Transmission
  96. Type "A" hydra-matic transmission fluid
  97. 1996 Transmission Performance Capabilities
  98. Black Rubber Washer thing...Help
  99. Th200 To Th350 Swap Out
  100. TH400 wire hook up
  101. TH400 torque convertor identification
  102. 455 to 425 th400 swap?
  103. th400 rebuild info
  104. Hydramatic Slim Jim options
  105. need help with early 50's hdyramatic
  106. Tranny wires
  107. Need To Re Do A/c For A 1970 Cutlass
  108. 1970 Cutlass Revive
  109. 65 starfire hydramatic trans diagram
  110. 400 to 2004r swap
  111. Transmission interchange
  112. Shifts hard
  113. '65 Jetstar 88 Speedo question
  114. swap auto with 4 speed? howto??
  115. '71 Cutlass Supreme in need of Transmission
  116. TH400 swap in 84 Cutlass
  117. '80 4 speed?
  118. 330-early 400 manual flywheel
  119. 1969 Olds Toronado Transmission Information
  120. TH350 to TH400 Conversion Yoke question
  121. Slips when cold
  122. 1964 Oldsmobile Transmission Problems
  123. 350 gear ratios
  124. 1964 Oldsmobile 98 Tranny
  125. Came by a '76 w/ a 3-speed on column.....
  126. 66' 425 trying to make it manual
  127. 55 olds 88 - Transmission fluid
  128. ~ still need help with turbo hydromatic problems....
  129. Hydromatic linkage adjustments
  130. i still need a b.o.p. th-400...
  131. Speedometer Gears
  132. 55 Olds Hydramatic transmission - Newbie
  133. Detent Cable???
  134. 59 Hydromatic Front Pump Seal
  135. i need a date coded rebuildable th-400
  136. '69 cutlass 350th trans issues,,,
  137. THM400 to 5 or 6 Speed manual swap?
  138. 1965 olds starfire hydramatic problems...help appreciated
  139. Question on Engine/Transmission on 85 Cutlass
  140. GM tranny compatibilty?
  141. 2004r question
  142. Newbie here,...question on olds 303 to Chevy adapters
  143. 65 starfire transmission
  144. manual trannies for 350R
  145. '87 Cutlass 2004R Trans issue/Concern
  146. 400 trany
  147. Jetaway
  148. transmission
  149. Stock 2 speed swap to built up TH350
  150. harmonic balancer problems
  151. 1974 z-bar setup
  152. T56 6 speed from camaro/firebird Tranny swap
  153. What's Needed 2 Swap th350 to th400?
  154. sorry for the error, (403 to 455
  155. 430 to 455 swap
  156. 425
  157. Stock Tranny
  158. shifter conversion kit
  159. trans swap th350 to th400
  160. tranny swap
  161. 71 Olds Cutlass Trans linkage
  162. Flex-plate and Harmonic Balancer
  163. 1975 cutlass supreme coupe (hurst options)
  164. Tranny Swap
  165. lightning rods
  166. adjustment after cat converter removal
  167. transmission shifts at high rpms
