PDA
View Full Version : Transmission
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13
  1. Trans adapter plate TCI 230000
  2. Speedo cable leak at T/M case
  3. 1970 T350 leak at the slip yoke
  4. Governor Recalibration Kit & Stock Shift Points?
  5. Yet another 200r4 question
  6. SHift kit install time
  7. OW stamp upside down on W-30 transmission
  8. Torque Convertor
  9. good factory style clutch and pressure plate..
  10. Torque convertors explained vidios and more
  11. 1956 flexplate problem
  12. giving up on th400, what 2004r to choose
  13. transmission swap
  14. Tranny Blues
  15. Is my rod too short? ...68-442 4-speed problem
  16. Transmission problem
  17. Shifter cable
  18. 1965 f/s Olds: TH400 Short- or Long-tail?
  19. 1965 F85 Jetaway trans leaks only when is storage
  20. Gear needle stuck in Low
  21. Sub Standard Upshift Diagnosis
  22. Transmission Fluid
  23. Filter number please?
  24. TH400 Oil Seal
  25. 63 Cutlass Roto-5,No shift into 4th gear.How do I adjust it?
  26. Hard Shifting Into Gear
  27. want to do a 200r4 in 72 cutlass
  28. Leaky tranny
  29. T-5 feasibility behind a 72 350
  30. Bell Housing Question
  31. th400 wont shift in drive to 3rd
  32. transmission from Delta 88
  33. help me identify this please
  34. Lucas Transmission Treatment
  35. Gear engagement/Shift Linkage adjustment
  36. Th400 tranny not shifting
  37. TH400 Rebuild Suggestions
  38. Aurora V8 conversion
  39. No Speedometer provision
  40. Will this transmission fit my '66?
  41. transmission has to warm up?
  42. Tranny Temp Sensor
  43. transmission rebuild kit suggestions
  44. 200r4 forward clutch shaft failure
  45. Shiftworks kit
  46. Best TH 400 Shift Kit
  47. Th400 rebuild..
  48. Transmission Failure... any help?
  49. 700R4 Lockup
  50. Automatic to 4 speed conversion
  51. TH 400 Trans Modulator
  52. 1955 hydramatic- no drive
  53. ST-300 tail shaft seal or bearing question
  54. Keisler SS700 5 Speed Overdrive
  55. Late Shift TH-350
  56. Kickdown cable not moving on TH-350
  57. Toro TH400 fluid boiling
  58. Please Help Diagnose Problem
  59. Bad modulator TH-350
  60. 64 Cutlass - Rochester 4Jet w/ 200R4 TV bracket
  61. Trany cooler lines...
  62. Anybody heard of this place
  63. How do I tell the difference 350 vs 400
  64. Whats the easiest trans swap for 67 C/S S.B ?
  65. TH 400 Shifter Opinions
  66. OG TH400 Marking
  67. 71 98 trans rebuild best torque coverter option
  68. st300 question
  69. dual gate shifter fake?
  70. Variable Pitch /Switch Pitch Turbo 400
  71. jetaway,until she goes into 3rd anyway
  72. Question about Muncie vs Saginaw
  73. Question about a Dual gate shifter
  74. 4 speed value
  75. Cutlass Xmsn swap question
  76. Transmission match.
  77. gosh darn tranny!
  78. Downshift Switch adjustment..
  79. Trans numbers ? Help..
  80. switching from m21 to m20
  81. throttle/trans cable bracket
  82. I give up on Lockup Torque Converter
  83. Replacing a Hydromatic with a standard Transmission
  84. BOP Th350
  85. T5 transmission mated to Olds 215 Engine
  86. Downshift cable
  87. another TH350 shift point question...
  88. Best trans cooling options
  89. compatibility of dual gate shifter
  90. Gasket recommendation kind and brand pla thanks....
  91. 200-4R Trans ID
  92. Th400 fluid
  93. Still Looking for a TH350
  94. 67 cutlass 4 speed swap
  95. Was this a 4 speed?
  96. 200-4R Bellhousing Pattern Recognition
  97. Help with a transmission question?
  98. 200-4R TV cable linkage ?
  99. 200r4 gears question
  100. stiff linkage
  101. TH400 shifting issues
  102. Torque converter hardware
  103. Manual lever and equalizer bushings where to buy?
  104. Tranny Builder in the Pacific NW
  105. TH350 adjustment
  106. TH2004r vendors?
  107. 200 4r in a delta 88
  108. Th375?
  109. good trans guy in san diego
  110. Tranny blues
  111. 700r4 cable sweep question (on a 455)
  112. Will this Fit in my car?
  113. Overdrive for 64-66 330?
  114. shift linkage
  115. OMG!...Help?
  116. 6 spd manual for 1972 cutlass
  117. TH 350 valve body questions
  118. edelbrock 1406 and 200r4
  119. TH 350 manual / automatic valve body
  120. Jetaway Trans.
  121. filter change dumb question
  122. turbo 400 pan
  123. Transmission cooling lines
  124. Th 400 = th 400 ?
  125. 200-4r with 455
  126. 63 Slim Jim Filter Change
  127. Slipping Transmission
  128. 1955 Hydramatic that has been sitting.
  129. TH 400 Compatable with 350 and 455?
  130. 4 Speed Swap
  131. Marking Colors TH-400?
  132. Possible to convert to TH350 and floor shift for $800 or less?
  133. Transmission Rebuild Chicago recommendations
  134. 69 Cutlass Speedo cable length
  135. 1969 m21
  136. slim jim help
  137. TH-400 shifts too late
  138. My 52 shifts too early
  139. Dynaflow question
  140. Buzzing
  141. Adding Lucas treatment to ST300 2 Speed Jetaway?
  142. Slow to engage after sitting
  143. Perplexed in Peshtigo
  144. what muncie is this?
  145. 4 Speed Linkage Questions
  146. Th-400
  147. Too much play in dual gate shifter
  148. trans temp sensor.
  149. Need dimensions for the 200-R4 output shaft support tool J-25013-1
  150. question
  151. 4 speed AOD
  152. Mystery Converter
  153. T-10 m-20 m-21 m-22
  154. Gear Venders under/overdrive units.
  155. Roto Hydramatic 5 rebuild?
  156. Transmission valve.
  157. TH350 Slipping...debris in filter
  158. Turbo 400 shifting issue
  159. BW T10 Issues?
  160. Hurst Pistol Grip Quarter stick shifter
  161. Torque Converter Stall speed??
  162. 1967 Olds442 convertible
  163. 2004r Torque converter fluid question
  164. Installing console with automatic shifter
  165. Trans temp sensor location on 200 4r?????
  166. 1950 Hydromatic
  167. Muncie-M21 1967-68?
  168. auto-5speed
  169. 72 Cutlass w/stock 3 spd Trans
  170. TH350 spewing fluid on startup
  171. Tranny won't fully engage in park.
  172. Which Clutch Set Up to buy?
  173. 200-r4
  174. Can we use Water Temp gauge for Transmission Oil Temp
  175. 69 CUTLASS 700 R4 SWAP step by step
  176. BOP 9778882 vs. 9785581 bellhousing
  177. 200r4 making noise
  178. Flywheel Inspection Cover
  179. Buying a used th350.....
  180. TH 350 questions
  181. Hard to find transmission parts:
  182. 69 442 best Trans Fluid?
  183. Will a 67 Jetway tranny fit on a 1969 455?
  184. Speedometer Gear Seal
  185. 57 Jetaway no 2nd upshift
  186. Storing a transmission...
  187. PRW flywheel
  188. 1969 442; Shifter wont go back into "P-Park"
  189. will my dipstick tube from my jetaway
  190. 3 Speed automatic with Overdrive...
  191. Slim Jim swap
  192. hydraulic clutch in a 68??
  193. Looking To Trade M20 Tail Housing
  194. 1968 Manual Transmission Bell Housing Inspection Cover
  195. lakewood alignment kit
  196. Turbo 350, 400 Restoration
  197. th350 no forward gears/swap question
  198. 350 Trans Tail Bearing
  199. Torque converter manufacture
  200. th350 takin a leak
  201. TH350 from Nova any good?
  202. Cooler line routing
  203. Will it hurt?
  204. 68 Cutlass Tranny Swap - Flywheel Question
  205. 1963 F85 shifting
  206. 1964 394 Olds Transmission Conversion
  207. Auto to Manual trans conversion?
  208. 200r4 kickdown cable bracket ??
  209. TH 400 i.d. plate
  210. I need some help, it says 79 CK hydramatic
  211. dipstick and dustcover
  212. Block off modulator vacuum supply for higher shift points?
  213. 52 hydramatic shifting
  214. Th400 won't reverse???
  215. Fittings
  216. Stripped Bolt on Torque Converter
  217. Keeping the stealth look with a 200R4
  218. Shifter locking up
  219. TH400 shifting problem
  220. 200-4r behind a 455
  221. Manual transmission for olds.
  222. Th 400
  223. TH350 Tranny Problems
  224. help with the jetaway
  225. 2 speed Jetaway hesitation at 40-50mph
  226. rebuilding th350 or 200r4
  227. Car shifting hard
  228. Can anyone rebuild a 1963 roto-5 hydramatic? Pittsburgh-Youngstown area
  229. 1970 Automatic Shifter - Take Apart
  230. ShiftWorks shifter install
  231. 71 Cutlass S
  232. Kickdown adjustment on 70 Cutlass S
  233. Putting a 200R4 in my 65 Cutlass
  234. muncie or T10
  235. How do I know if the transmission is in the TC far enough?
  236. Trans For Sale (Not Mine)
  237. M21 or M22
  238. trans wont go into park
  239. manual flywheel difference
  240. Teflon tape
  241. Hydramatic
  242. Lakewood Scatter Shield
  243. Speed sensor??
  244. 2.56 rear and close ratio Muncie
  245. Is this a good deal on a TH350?
  246. Gear Vendors overdrive unit in my 65??
  247. Swap for 200-4R or repair TH350, which should I do?
  248. Turbo 350 dust cover
  249. Leaky situations-55 Super 88
  250. Need help...
