Transmission match.
Old Jun 11, 2012 | 09:27 AM
renutter's Avatar
Transmission match.
What of the newer transmissions ( th350 th400 etc.) would be the best and easiest match for a 371 ci olds in a 1950 98?
Old Jun 13, 2012 | 09:04 PM
Tedd Thompson's Avatar
If I haven't answered this somewhere else on this forum here it goes again.
#1 there are no direct bolt up matches from a first generation Olds motor to a 350 or 400 trans, all will require an adapter( Ross Racing is probably your best place to get one) not cheep but good.
#2 should you go this route I would just use a TH350 because it is a little lighter and plenty strong enough behind a 371, both should fit under the transmission hump because they are both smaller than a stock hydro.
#3 keep in mind that you will have to change (or manufacture) the transmission mounts and all the linkage and drive line.
#4 you could have two stock hydros professionally rebuilt cheaper than all the above...Tedd
Old Jun 13, 2012 | 09:35 PM
Fakser's Avatar
I just love hearing newer transmissions and TH350 and TH400 in the same sentence.
Old Jun 14, 2012 | 06:02 AM
rocketraider's Avatar
Oldsdruid
So do I! I had a 400 rebuilt in 2000, and there was ONE person in that shop who was familiar with them. It struck me then that they hadn't been produced since 1986 and were on their way to becoming the Hydro and SlimJim of their time.
Old Jun 14, 2012 | 06:46 AM
Where does time go...Still lost in the fifties... Tedd
Old Jun 14, 2012 | 01:07 PM
renutter's Avatar
I thank you again for your information.
hoppers69
Apr 30, 2012 06:55 PM
Ne_stang
May 7, 2009 03:08 AM
Charlie_brown
Jan 25, 2009 11:36 AM
Feb 24, 2008 06:08 PM
Deepsouthauto
Mar 20, 2006 04:14 AM
