Teflon tape
Old Nov 13, 2011 | 05:53 AM
WHIPOLDS's Avatar
Teflon tape
I will be replacing my transmission coolant lines on my 56 Olds. Do you guys / gals use teflon tape on the fittings?
Rick
Old Nov 13, 2011 | 06:00 AM
citcapp's Avatar
At the radiator yes, at the transmission no the lines are flared where they connect to the flexible line
Old Nov 13, 2011 | 06:07 AM
WHIPOLDS's Avatar
Thanks Citcapp - What is your opinion of going to the flexible braided lines instead of the steel tubing?
Old Nov 13, 2011 | 06:10 AM
citcapp's Avatar
seeing as how I know hard lines don't fail and have lasted 55 years + in a stock 56 old I would stick with them. Braided likes still have rubber or other material in them that can fail. Besides I am cheap and bend my own lines with a $10.00 hand bender
Old Nov 13, 2011 | 06:16 AM
WHIPOLDS's Avatar
Good point ! I will keep it original.
Thanks !
Old Nov 13, 2011 | 01:19 PM
rocketraider's Avatar
Oldsdruid
I think I'd stay away from teflon tape here. If even a tiny piece of the stuff breaks off and gets into the transmission, it can wreak havoc as it could plug a passage or get stuck in the valve body.
Old Nov 13, 2011 | 04:59 PM
501Paratrooper's Avatar
There is a liquid Teflon tape.
Old Nov 13, 2011 | 06:07 PM
citcapp's Avatar
Rocket raider is correct on this, my bad. I checked it out the fittings going into the radiator are flared as well don't need anything there either
W70442
Mar 4, 2017 12:27 PM
72EPCutlass
Jan 1, 2014 04:38 PM
stlbluesbrother
Nov 23, 2009 08:56 AM
Bluevista
Feb 21, 2009 09:21 PM
69'442
Apr 17, 2008 11:34 AM
