Best trans cooling options
Old May 23, 2012 | 02:09 PM
Nasty455's Avatar
XCELERATIONRULES!
Does it matter whether the input lines enter the radiator from the top or bottom?
I'm guessing plumbing from the bottom would slow the fluid flow slightly increasing the cooling time in the radiator.
Anyone know which line coming off a turbo 350 is the outlet?
Thanks.
Old May 23, 2012 | 02:28 PM
GAOldsman's Avatar
"Car"mudgeon
Upper line is the return line from the upper portion of the radiator. Refer to page 7-112 here
So to answer your question the bottom is the outlet on the TH350.
Also I would recommend an additional external transmission cooler on any application that will see any towing, racing or a lot of stopping and starting conditions.
Old May 23, 2012 | 06:51 PM
Nasty455's Avatar
XCELERATIONRULES!
Thanks.
I got the info from another site,thought I'd share it.
Top to top,bottom to bottom.
Bottom line off trans = output
(Bottom) of radiator= (input).
Easy!
Old May 23, 2012 | 08:47 PM
BILL DEMMER's Avatar
Just the facts...
think about it, it would be very hard to purge air from the cooler if the fluid flowed from the top down.
bill
olds 307 and 403
Apr 13, 2014 09:25 AM
QS442
Nov 28, 2013 07:54 AM
scrappie
Sep 16, 2012 04:07 AM
Jul 5, 2012 09:34 AM
KZ442
May 29, 2011 04:58 AM
