ST-300 tail shaft seal or bearing question
Old Jul 6, 2012 | 02:20 PM
at3reg98's Avatar
New 2 Olds
On my '65, I believe it has the Jetaway variable-vane trans or ST-300. Not sure still new to these cars.. it's a two speed and I see the three wire mechanism up by the rear of the engine.
At any rate the output shaft seal leaks and appears to have been replaced before. I notice I can push the shaft/yoke upwards so there is obviously some play causing the seal to wear and leak. Is this anything I can fix with the trans in the car? Not sure what I'm dealing with here. Looks like the tail of the trans can be removed.
Old Jul 6, 2012 | 02:26 PM
garys 68's Avatar
A few shops may have a bushing puller for a th350 and th400 yoke that can be done with trans in the car. Do you know what type of yoke yours has?
Old Jul 6, 2012 | 02:38 PM
There is going to be some play in there with the yoke out, minimal with it in. The seal should be easy to get at the parts store.
Old Jul 6, 2012 | 03:16 PM
at3reg98's Avatar
New 2 Olds
I would just put a new seal in but it'll wear again until I get the bearing fixed. I believe what I need is a "tail housing extension bushing." The vertical play is the problem; it droops (slip yoke in/driveshaft hooked up), just not centered in the seal. If anyone knows where to get one for this, that would help.
Old Jul 6, 2012 | 07:33 PM
442scotty's Avatar
www.fatsco.net This is where I got mine for my ST300. Still have to install it.
Old Jul 6, 2012 | 09:35 PM
at3reg98's Avatar
New 2 Olds
Thanks, I found some here as well: http://www.bulkpart.com/2/category/ST300.html
Old Jul 7, 2012 | 12:49 AM
garys 68's Avatar
here's the tool you need. You'll need to know what size yoke/bushing though first.
http://atoztool.com/2200.html
at3reg98
Aug 17, 2013 10:59 PM
jensenracing77
Drivetrain/Differentials
Jul 17, 2013 09:11 PM
bullet1
Sep 3, 2009 04:55 AM
Flye
Jul 30, 2009 10:24 AM
7244too
Nov 6, 2008 09:27 AM
