ST-300 Tail shaft bushing questions
Old Aug 17, 2013 | 12:10 AM
at3reg98's Avatar
New 2 Olds
Question ST-300 Tail shaft bushing questions
I need to replace the tail shaft bushing on my trans, as you can see it's making a mess of the underside of the car. It's more than the seal, there is obvious play when I move the driveshaft.
Is it possible to remove the tail housing and repair it on the bench or would that be opening a can of worms? I see there's a tool to do it in the car: http://atoztool.com/2200.html but I'd rather not spend that for a one time repair. Can I improvise somehow?
I bought this seal and bushing kit below.
Old Aug 17, 2013 | 07:36 PM
Its pretty simple once the extension housing is unbolted. Unhook the speedo cable,remove the driveshaft, 4 bolts and its off. You can use a chisel to cut out the bushing and seal, but you will need a bushing driver to install the bushing without mangling it. I have used a camshaft bearing installation tool to install oddball bushings, or take the extension housing to a trans shop to be installed
Old Aug 17, 2013 | 08:09 PM
svnt442's Avatar
I had an issue (of my own doing) with my TH400 and I had the tail shaft off so I just took it over to a trans shop and the guy sold me a new bushing and installed in on the bench for $20. I was happy with that as it saved me all sorts of time and I wanted to get my car back on the road ASAP.
Old Aug 17, 2013 | 10:54 PM
at3reg98's Avatar
New 2 Olds
Sounds good, I was thinking if I had a socket the same diameter as the bushing I could drive it in slowly and carefully if that would work.
Are there gaskets and seals I should replace while I have it off? I was thinking of the speedometer o-ring(s) but is there a gasket for the tail housing to case I need to get?
Old Aug 17, 2013 | 10:59 PM
svnt442's Avatar
It might have a gasket. If that's the case it should be cheap.
NMcCarthy
Nov 17, 2014 07:32 PM
at3reg98
Jul 7, 2012 12:49 AM
Frogge467
Mar 24, 2012 11:09 PM
ROCKET VAPOR
Jun 20, 2011 06:50 PM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
