A9 wheel Bearing - Which side of bearing is toward retainer?
8.5 bolt in Axle-71 Olds
A9 Bearing, wheel/axle bearing.
It definitely is NOT symetrical from a top view. It bulges slightly more on one side than the other. It has an extra 'band' on one side, and is 'open' on the other. There has to be a side that goes in first that is against the retainer, and the other side, obviously faces out toward retainer/wheel. See Pics.
My question is:
"Which way does it install?"
My question is:
Yes its pressed onto the axle when you hold the bearing in your hands and push the inner part you can feel it pressing into the outer ring turn it around and it pushes apart or away from the outer ring.
a9 install direction help
Here is a helpful picture I hope...lol
Green is the housing
red is the retaining plate blue is the seal
The bearing is correct in the housing - just do it like the picture. Jim
muscle car resto
Drivetrain/Differentials
May 26th, 2015 07:44 PM
62 Olds
March 24th, 2015 06:51 PM
