want to do a 200r4 in 72 cutlass
Old Aug 22, 2012 | 08:47 AM
mdfedewa's Avatar
what do i need to drop in a 200r4 trans? can i buy the right crossmeber? thanks
Old Aug 22, 2012 | 09:21 AM
455man's Avatar
There are lots of threads on this I'd do a search. I think the crossmember just needs moved back.
Old Aug 22, 2012 | 09:48 AM
And you need to adapt the carb to work with a TV cable. The 2004r trans requires a TV cable to work correctly.
Old Aug 22, 2012 | 10:14 AM
bccan's Avatar
Trans, Converter, Rear Mount
TV Cable, TV Cable Carb Brkt (OE not hard to find on Parts Wanted Forums)
Some type of lockup circuit, if wanted - search here & ROP for threads.
Your driveshaft & xmbr should work. I reuse TH350 dipstick, tube, dust cover.
Carb throttle arm mod or change to proper TV stud type.
If you want manual access to low gear, mod column detent / shifter detent.
Metric converter & rear mount bolts.
TH400 primary e-brake cable & shorter secondary cable (I just shorten it & use a uni stop)
delta254
27
Jun 3, 2020 03:52 PM
mat1227
Oct 16, 2013 03:41 PM
MrPorkchops
Jun 27, 2012 09:34 PM
jag1886
Dec 18, 2011 06:58 AM
dhoff
Sep 5, 2009 07:28 AM
