throttle/trans cable bracket
Old Jun 5, 2012 | 05:22 AM
72 Supreme's Avatar
Can anyone let me know where to get the bracket(throttle/trans cable) that is needed to convert over to the 200r4 transmission in a 68 Cutlass S. Any info would be greatly appreciated.
Thanks,
Doug
Old Jun 5, 2012 | 07:34 AM
Doomah's Avatar
Not sure if it is the same and if this is what you are talking about but here
http://www.summitracing.com/parts/MRG-6039/
Old Jun 5, 2012 | 03:06 PM
oddball's Avatar
TCI's bracket is pretty nice. That gets the TV cable mounted solidly.
You still need to attach the cable to the carb. That is far more complicated for a stock qjet, but don't know what carb you're running. Bowtie overdrives has various options that may or may not be applicable. One way for a stock Olds qjet is to get a later-year base plate and swap over the bracket. This requires machining, mine is being done by Sparky (sparky carburetors).
Old Jun 5, 2012 | 03:14 PM
Why not just go to a boneyard and pull one from a car? There's got to be plenty of them in there and the price will be better than new.
Old Jun 5, 2012 | 03:23 PM
tru-blue 442's Avatar
Old School Olds
Is it not true that you can take a late model
Q-jet, say from a vintage 80's Cutlass with a 307 & remove the
primary flaps, slide the armature out and use it on
the exsiting 68 Q-jet and have the factory set up and be able
to use the 68 baseplate? This is what I am hoping to do with
my 69 442 and 200 4R. I have already found the bracket that
bolts to the back bolts of the carb. Didn't mean to hijack the thread...
Old Jun 5, 2012 | 03:35 PM
Octania's Avatar
Possibly.
Avoid the electronic carbs I guess if you want to swap entire base plates, because the Accel. Pump rod is fatter on the e-carbs, turns ugly.
SHAFT removal and swap might just do it.
Also, beware the 70-72 trans cable which has a smaller square sheath mount, same size as throttle cable, it was to fit into place at the firewall/ pedal, not at the carb bracket.
Old Jun 5, 2012 | 05:08 PM
BILL DEMMER's Avatar
Just the facts...
no, the 1705/1708 m4m/e4m carb. primary throttle shaft is too long. you can graft the newer end on to the older shaft though.
bill
Old Jun 6, 2012 | 05:22 AM
Old School Olds
Good info. Thanks Bill, Chris.
I have a later model chebby carb
that I maybe able to use the shaft from.
I set it on my D-2 intake and with the gasket
it just clears the heat crossover. It may get to
hot and fry the cable though, rats...
Old Jun 6, 2012 | 05:42 AM
72 Supreme's Avatar
Bracket
Thanks for the replies, I have someone looking for one in the local recycle yard and if I fail there I'm not that far away from several larger yards.
Thanks again,
Doug
Old Jun 6, 2012 | 01:42 PM
Old School Olds
Doug, thanks for asking the Question.
defiant1
Feb 4, 2020 08:53 PM
seok
Mar 15, 2011 10:53 AM
69oldsguy
Aug 25, 2010 07:42 AM
MJAKS462
Apr 7, 2010 03:14 PM
1k442
Dec 22, 2008 07:24 PM
