No Speedometer provision
Old Jul 29, 2012 | 06:56 PM
35mastr's Avatar
My Th 400 trans came out of a 68 olds 88. It has no provisions for a speedometer.Its still casted shut. Is there any kind of tailshaft that can be installed that has a provision for the speedometer. Then I could just install the gear on the shaft. I have been searching the net for hours to just come up short on this issue.
Old Jul 29, 2012 | 08:01 PM
tru-blue 442's Avatar
Old School Olds
George, I belive the 68-69 88's had
the speedo cable attached to the driver
side front wheel somehow.
I am not sure how to go about fixing
this problem. I think that where it
should fit is a plug that can be popped out
but I am not sure. You would then have to
drill and tap the spot for the retainer bolt.
Old Jul 29, 2012 | 08:20 PM
35mastr's Avatar
I know it was driven from the front wheel. It is still casted over and no plug can be removed. Thats why I was trying to figure out a tailshaft solution. I am sure that someone here has done this to get the speedo to work.
Old Jul 29, 2012 | 09:58 PM
BILL DEMMER's Avatar
Just the facts...
my th400 s.p. came out of a '67 delta 88, it had a cup plug that was removed, then a drive gear was installed on the output shaft and the driven gear was installed into the tranny case.
bill
Old Jul 30, 2012 | 06:53 AM
Sorry, but you're SOL. Some of these TH400s came with a cup plug that could be knocked out, some with the hole cast shut. Short of disassembling the trans and having the hole machined in the case, there's nothing you can do. Swapping tailhousings doesn't help because the speedo provision is in the main case, not the tailhousing. Either get a GPS speedo or use the tach as a speedo.
Old Jul 30, 2012 | 08:47 AM
35mastr's Avatar
bill
DO you have all the part numbers and tooth counts for the gears. Was the main shaft gear installed plastic or metal?
Old Jul 30, 2012 | 09:40 AM
35mastr's Avatar
From looking at the case,The main boss for the speedo is already machined into the case. Looks like the center needs to be taken out. I may just do it myself if it comes to that.
Old Jul 30, 2012 | 06:17 PM
Just the facts...
i had my tranny guy do it along with a re-seal. i selected the combo based on my tires/rims/gear ratio.
bill
oldrelics
Jul 28, 2014 03:28 PM
70 ctls
Dec 8, 2012 11:33 PM
magnusdog
Sep 14, 2006 01:03 PM
sharkey1967
Aug 29, 2006 11:45 AM
1965_F85
Feb 15, 2006 11:54 AM
