PDA
View Full Version : Transmission
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13
  1. 66 Starfire trans
  2. 4L80E swap into a '71 442 / 455
  3. 200R4 swap into Vista Cruiser
  4. TH200-R4 and dual gate shifter in a '71 442
  5. Wanted: Clutch Actuating Rod Photo (installed)
  6. 67 Olds kickdown switch electrical tabs?
  7. 455 with a TH400, Need BOP Housing?
  8. 86 cutlass want to swap to a manual trans
  9. How many seals can I replce without pulling the trans?
  10. 1973 olds with a 2004r trans
  11. Crossmember to frame rubber ends?
  12. 200-4r Converter Stall Question
  13. Braided Flexible Transmission lines
  14. 55 Olds--This is in the way...
  15. 3000 stall too much? or is 2200 not enough
  16. 350 tranny bracket problems
  17. Pilot bushing install
  18. need part # for '60 88 jetaway filter & gasket
  19. diesel th350 behind a gas engine?
  20. TH 400 Turbo problem!!
  21. Trans cooler questions
  22. T350 help needed
  23. need detent cable for th350 trans
  24. Trans problems..
  25. Trans "FLUSH" vs. Traditional Change Out?
  26. 69 cutlass kickdown cable attachment help?
  27. Swap Problem from Jetaway to Turbo 400
  28. 64 Jetaway to a 200R4
  29. Jetaway to th350 should I put in a Stall?
  30. EEK!!! no likey this noise
  31. Red varnish inside transmission
  32. Speedo ratio adapter
  33. TH350 rebuild question
  34. Muncie Tranny
  35. 65 - 442 Jetaway to a 350?
  36. Chicago jetaway service
  37. 63 starfire slim jim operation question?
  38. Chevy Olds adapter
  39. slim jim rear seal install ?'s
  40. High Rpm problems
  41. Transmission cross member mount bracket?
  42. '70 442 TH400 Kick down switch adjustment
  43. floor shifter to column conversion.
  44. changed from st300 to 350 turbo but?
  45. Transmission Leak Getting Worse
  46. Jetaway fuse keeps blowing any ideas?
  47. th400 questions
  48. Slim jim & lucas slip stop
  49. Dipstick handle color - '72 TH350
  50. replacing modulator on st300
  51. dual gate shifter alignment off
  52. New Transmission for my 70 Cutlass
  53. Questions on change from Jeyway to a tubro 400
  54. T5 swap...Will it work?
  55. Jetaway leak
  56. Wanted TH350 Valve body
  57. problem installing shift kit
  58. Th400 transmission motor smoke
  59. Super Turbine 300 performance mods
  60. what trans to use Turbo 350 or 200R4
  61. Knocking Noise When Hard Braking
  62. A Transmission for my 455
  63. TH-375 Vented Slip Yoke Problem
  64. Clutch replacement 69 Cutlass
  65. 455 on TH350 or 400
  66. Transgo shift kit mods
  67. 700r4 replacing original
  68. 70 SX trans code needed
  69. Tranny problems
  70. ST300 HP limit?
  71. 64 Olds Hydramatic high RPM Shift
  72. 72 TH-350 Detent Cable trouble
  73. Transmission leaking from the tube
  74. Speedometer gears
  75. Dipstick help for 350, swaped for a Jetaway 300
  76. 55 Olds - Machining Crank for Pilot Bushing
  77. jetaway to a 350 turbo
  78. Diff style Hurst shifters?
  79. th400 trans fluid
  80. 68 cutlass th400 swap
  81. 1964 2-speed slips in first
  82. TH350 no 2-3 shift
  83. 1980 TH-350 w/OD? factory?? does it exsist?
  84. Th400
  85. Slim Jim trouble. Spits oil out the dipstick
  86. 1972 Manual 4-Speed Transmissions
  87. 200R4 Shifting Issues
  88. 62 dynamic 88 hydramatic ?
  89. 68 2 Speed Auto rebuild kit?
  90. Muncie Problem or Clutch?
  91. Throttle Shaft Seal? 55 Olds
  92. Moving the crossmember
  93. Dexron VI anyone?
  94. Trans pan gasket preferences
  95. Super Turbine 300 value??
  96. transmission torque converter
  97. Tell me what the heck is going on!!
  98. Slim Jim care
  99. V-8 350 in a 1965 F-85?
  100. Identify this part?
  101. Swapping my Th400 for 700r4
  102. How many 3 speeds built 1972
  103. Trans control spark issue
  104. Stall Speed specifications 1970 TH400 OD
  105. Troubleshooting cut vacuum lines (and tranny shifting)
  106. TH400 Vacuum Modulator
  107. 1968 2 Speed Auto Transmission Jumping
  108. Bad electric down shifter switch??
  109. TH400 Selector Bracket
  110. 425 turbo
  111. 6speed manual for a 455 rocket?
  112. Jetaway differences between 65 & 68
  113. jetaway/TH350 swap detent bracket
  114. Manual Swap... crankshaft and speedo/column
  115. shifting between D and S th400
  116. 72 442 TH 400 Trans Cooling Lines
  117. TH-350 Problems
  118. Need help converting 2spd to 3spd shifter
  119. Turbo 400 Shift Cable Bracket question
  120. Shift points for TH400
  121. Transmission cable bracket
  122. 66 ST300/Jetaway
  123. transmission rebuild?
  124. The ten billionth 200R4 swap question
  125. clutch wont disengage
  126. 72 Cutlass Manual Trans Conversion
  127. need help figuring out what transmission came in my 64 f-85 cutlass
  128. 68 Jetaway torque converter, 350 trans
  129. 350/th350 swap for 455/th400 help?
  130. Making a 200R4 trans equal or just as strong as a 700R4
  131. Torque Convertor
  132. 67 Manual Trans. Conversion Help
  133. Rookie transmission question
  134. th-350 dipstick tube for a 38 cutlass?
  135. drive shaft length
  136. Question About Roto-Hydramatic "Slim Jim"
  137. Memory problem-tranny cooler lines '69 Delta
  138. 75 cutlass
  139. 63 f85 trans swap
  140. Looking for a good trans rebuild shop, NY/CT
  141. How hard is it to rebuild a Th400?
  142. torque converter help
  143. Detent Cable-350 Trans
  144. what overdrive automatic to run
  145. transmission help
  146. kickdown cable adjustment
  147. Is there a 2004r dust cover that matches 400ci block?
  148. Lightning Rod shifter question
  149. shift to early
  150. Cable Needed on Conversion to 2004r
  151. Transmission Pan
  152. Bellhousing bolts?
  153. How many converted from auto to 4spd?
  154. How to Soften a Jetaway Hydramatic 2-3 Shift
  155. Transmission/ rear-end 63' F85
  156. torque converter measurement
  157. 700r4 conversion-Rochester 4GC TV cable
  158. What speedometer gear do I need?
  159. 62 Starfire
  160. th350 reviews/recommendations
  161. Tranny Builders - Best flat edge snap ring pliers?
  162. Another th350 kickdown leak thread....
  163. Flushing transmission - safe or not?
  164. 700R4 tranny swap in 78 Cutlass
  165. Aux. transmission cooler with th350 trans?
  166. trans swap
  167. th400 long shaft??
  168. Parking brake cable question...
  169. Downshift Solenoid Valve Connector
  170. 1970 W-30 question
  171. 700 R4 or 200 4R?
  172. What is now Type A Trans Fluid?
  173. Reverse is slipping.Th350
  174. Muncie rebuild kit - Recommendations ?
  175. Mounting Tranny to Engine
  176. Th 400 and 2 spd converter interchangeable??
  177. th200 neutral is drive?? problems
  178. Th400 rebuild
  179. info for turbo350
  180. What's your Th400 dipstick read when cold?
  181. Driveshaft length Q
  182. M22 RPMs
  183. Another floor shifter problem
  184. Transmission Issues 1970 Cutlass Supreme
  185. who calculates the speedo gears for 2004r?
  186. Need 68/69 Dual Gate Installation Help
  187. OD Tranny ?
  188. OW tag = WRONG
  189. Pilot Bearing or Bushing?
  190. 200-4R tips / tricks $$ saved on tools I learned
  191. Driveshaft info needed (trans change)
  192. Dowl pins
  193. Transmission identification help...
  194. Seeking Edelbrock TV Bracket & Drive/Driven gears
  195. 70 olds 442 transmission
  196. Overdrive tranny opinions
  197. How to hook up cable to transmission
  198. 200-4R Yoke stuck on output shaft
  199. 1960 Olds Hydro oil leak repair
  200. Convertor from TH350 to TH400
  201. Flywheel bolt pattern?
  202. Can you identify trans in picture?
  203. 66 factory Competition Plus Shifter
  204. th400 switch pitch
  205. 455 engine-trans bolt pattern measurements
  206. are there really only 2 gears in my auto trans?
  207. Thoughts on this 2004R ??
  208. 200 R4 vs 4T80E
  209. When--and in what--did a manual transmission appear?
  210. '65 442 Tranny
  211. need 455 flywheel min thickness spec
  212. Bolt Patterns
  213. Th400 vehicle weight limits
  214. Slipping transmission
  215. 55 Olds Transmission Cooling Lines
  216. Converting Auto to a Manual (Crankshaft Pilot Bearing)
  217. Modulator Adjustment
  218. Which th350 to get...
  219. TH 400 chevy
  220. Aftermarket Converter for SP TH400
  221. Flywheel availability
  222. TH400 switch pitch + gear vendor?
  223. jetaway trans
  224. M41 trans
  225. Column Shift to Floor Shift
  226. over drive
  227. 1972 Cutlass Hurst Dual Gate Shifter Questions
  228. Dual Gate swap out
  229. Kickdown and Switch Pitch Solenoid replacement in ST-300 Jetaway
  230. 76 cutlass accelerator pedal kickdown cable
  231. 67 OG code Turbo 400
  232. Clutches???
  233. Tranny seals
  234. 350 turbo tranny
  235. Picture of a 70-72 4 speed no console?
  236. Intake trouble!
  237. Tuning up a 5yr sitting Hydra-matic 4-S
  238. 5-spd manual trans
  239. How to know if trans is original
  240. 72 cutlass - tranny grinds when shift into park
  241. Brand of Clutch for '67 442
  242. Switch Pitch Pics or Diagram
  243. 200 R4 question
  244. 700R4 Question
  245. Torque Converter
  246. 4-spd console or w/o?
  247. 62 starfire trans linkage adjustment
  248. long shaft or short shaft....what do I use?
  249. Hurst Competition Plus Shifter
  250. What is a '76 TH400 worth?
