TH350 rebuild question
I'm in the middle of a th350 rebuild. I'm trying to get the retaining spring for the low/reverse drum out, and I cant. Maybe its my bad snap ring pliers, maybe I need a better tool. Anyhow, I have the clutch springs compressed (with the compressor tool) and am having trouble getting this ring out. Anyone have a tool/better method for doing this?
Are you referring to the low/reverse piston in the back of the case? They can sometimes be a pita to remove! I use snap ring pliers from Mac tools, but any would work as long as the tips are thin enough to fit in the snap ring groove.
ddd777
Feb 27, 2013 07:18 AM
