Column Shift to Floor Shift
Old Jan 9, 2011 | 04:24 PM
theoldsrocket's Avatar
http://www.youtube.com/wa
I have a column shift in right now and i am putting in a floor shifter i have the shifter and the brackets and the cable what other small parts will i be needing please help
Old Jan 10, 2011 | 08:48 AM
507OLDS's Avatar
Not sure what brackets you have,but here is a complete list of parts needed to convert a car from column shift to floor shift:
shifter assembly
shifter cable
cable bracket that mounts to trans pan
cable selector lever that mounts to trans
complete console with top plate
console mounting brackets- rear gets welded,front gets 2 screws
console harness & console extension harness
floorshift steering column
floor shift speedo
If you are also installing buckets,then you will need a set of the bucket seat mounting brackets,that get welded to the floor.2 main rails towards the inside,and 2 small perches at the forward outer postion.
shamusj
Apr 27, 2021 05:45 AM
hvysupreme
Feb 18, 2017 12:40 PM
Rocketbrian
Oct 2, 2013 10:18 AM
Bitburger
Dec 30, 2012 04:49 PM
Alocatelli
Dec 10, 2012 07:49 AM
