TH400 Selector Bracket
Old Jun 6, 2011 | 06:25 PM
TripDeuces's Avatar
Anyone have a close up picture of one of these? Particularly the rectangular slot the shifter cable hold down goes in. My Dual Gate will not go into 1st gear and I'm wondering if that hole is possibly stamped wrong or the bracket on the pan is somehow to blame. Any other suggestions are welcome. It seems to be off by about half a tooth.
Old Jun 6, 2011 | 06:37 PM
oldsconv's Avatar
I have a 70sx conv with original normal console shift and I added dual gate. I have Same exact issue. I used an Original dual gate shifter and gm cable of correct length but selector bracket is repro. I still have not fixed it but I am thinking I need to make that rectangular slot longer so the cable can move more but it might throw off the park setting.
Old Jun 6, 2011 | 06:42 PM
TripDeuces's Avatar
Exactly, I already elongated the slot and tomorrow I'll put it on and see where I'm at. I added roughly 3/8 inch more travel by elongating the slot towards the front. I've got the car to start in neutral but it's so close to reverse occasionally it will lurch, can't have that. Once I get 1st gear I can reset the neutral safety switch and be gtg.
Old Jun 6, 2011 | 07:42 PM
2blu442's Avatar
George, are you talking about the hole in the floorboard? Many years ago I cut out the floorpans from a couple cars I'd parted out. The brown panel is from a 1971 Cutlass Supreme with the single gate shifter. The green one is from a 1972 Cutlass Supreme with a dual gate. Yes, the hole for the dual gate is further forward than the single gate. Here's some photos. John
Old Jun 6, 2011 | 07:48 PM
2blu442's Avatar
I just read back through your post and am thinking I'm on the wrong track If you would describe the part and it's location that you'd like to see a picture of I may be able to get it for you. John
Old Jun 6, 2011 | 07:49 PM
TripDeuces's Avatar
No Blue I'm talking about the lever that attaches to the selector shaft coming out of the trans.
Old Jun 6, 2011 | 08:17 PM
TripDeuces's Avatar
While looking for the picture of the part from where I bought it, The Parts Place. It seems it's no longer available. This by itself raises questions. The cable pin and the cable support bracket which mounts on the trans pan are still listed but the selector lever is not.
Maybe it was removed because of problems?
My rectangular slot is biased towards the rear of the lever which may or may not be the problem. This is the reason I wanted to see another one to gauge mine by. Today I lengthened the slot forward about 3/8 inch. I guess I'll know tomorrow.
Old Jun 6, 2011 | 08:51 PM
2blu442's Avatar
I thought I could easily lay my hands on one, but I struck out. If your still having problems by next weekend let me know and I'll try again to come up with a factory one to measure and photograph for you. John
Old Jun 7, 2011 | 07:41 AM
507OLDS's Avatar
The original floorshift selector levers that came on the Cutlass/442 are different than the new ones available,or the GM replacement.The ones available now are the same as the 70's Camaro/Firebird,and possible others.If you actually lay them next to each other,you can see that the positioning is NOT exactly the same.
Old Jun 7, 2011 | 08:52 AM
TripDeuces's Avatar
The problem is solved. It turns out it was the new lever. By making the slot 3/8 inch longer and pushing the pin as far forward as it will go it now works fine. I now have all gears and with a slight adjustment of the neutral safety/reverse switch it works like a dream.
Thanks for all the input all.
George
Old Jun 7, 2011 | 10:51 PM
lrbeavers's Avatar
can you guy still post the pictures,I am converting a B&M floor shifter to an original Shifter and I am in need of some gudiance. I am having a simalar problem locating the lever that connects to the trans. the cable, mounting bracket and pin set is different, so i hopefully purcharsed the correct items and now the selector lever is different, where can i find one for a TH350.
Old Jun 8, 2011 | 07:21 AM
TripDeuces's Avatar
All from The Parts Place Inc. Since I didn't know what year your car was I picked a 70 Cutlass. All listed under console parts. The selector lever is no longer offered but it is listed under 70's F Bodies, Camaro and Firebird, like 507Olds said. You may run into the same problem I had and need to modify the lever. Sorry there is no picture of the selector lever shown.
Old Mar 29, 2013 | 06:05 PM
69'442's Avatar
I can't get first gear. Is this the selector bracket that I need to elongate the slot in for the dual gate setup? If so, can you please tell me how to do this using the picture. Thanks, Bob
Old Mar 29, 2013 | 07:11 PM
TripDeuces's Avatar
69'442 that is the selector bracket I'm talking about. If yours is the one pictured then your slot should be long enough. That is much longer than mine was. If you're still having problems also look into the bracket that bolts to the pan rail. It may be able to slide forward and aft.
I don't have any pics to show.
Old Mar 29, 2013 | 07:22 PM
69'442's Avatar
This is the other one I have.
507OLDS's Avatar
The bracket pictured usually needs modified.Yes the slot is longer than the originals,but the position or clocking is different.
Old Mar 29, 2013 | 07:25 PM
69'442's Avatar
Brian, Can you somehow show how to modify it.
Old Mar 29, 2013 | 07:27 PM
TripDeuces's Avatar
You make the slot longer toward the front of the car.
My point is the bracket you are showing can not be made longer, there is no room. So is the one you are actually using have the same size hole?
Old Mar 29, 2013 | 07:30 PM
69'442's Avatar
Yes, That is the bracket I am using.
Old Mar 29, 2013 | 07:45 PM
TripDeuces's Avatar
If you can't elongate that slot then the bracket bolted to the pan rail needs to come backward so it goes into 1st gear when the selector is in that position. At least that's my memory of it. If I'm not mistaken the bracket on the pan rail has elongated holes for adjustment?
This thread is two years old. You can't expect an senile old bastard to remember this stuff
Old Mar 30, 2013 | 11:53 AM
Doomah's Avatar
I am having a similar problem, I am going from column to floor shifter and I brought the silver bracket but i can't seem to figure out how to connect it the shifter cable. When i look in the Assembly manual the brackets dont look the same and the silver bracket doesn't have a place to connect the shifter cable. Does anyone know what i am doing wrong?
Delmont 88 PA
Jul 24, 2014 05:30 PM
hotrod
Aug 12, 2013 01:06 AM
deltaroads
Apr 25, 2011 03:36 PM
FATRATMATT
Oct 16, 2008 04:21 AM
carnell71075
Nov 21, 2007 03:26 AM
