changed from st300 to 350 turbo but?
I changed me tranny from the old st300 to a 350 turbo on my 64 olds. But the 350 has no plug on it anyplace for the electrical plug for the backup lights and i guess the neutral safety switch. Do the newer ones work in a different way than the old cars do? Like maybe switched at the column? Other than that the tranny switch was no problem.
thanks so now i have to figure out how to make mine work. And about the extra gear for shifter im thinking of going with an aftermarket floor shifter that looks like a 4-speed. OH! duh,the new shifter should have something for the switch.
The only electrical plug on the ST300 was for the kickdown and the switch pitch torque converter. The TH350 doesn't use those. The neutral safety switch and the backup light switch were on the shifter and won't change when you change the trans.
Um, the ST300 didn't have those plugs on the trans either...
Hey now don,t beat me down LOL, I am totally new to the Oldsmobile brand since I was 16 and now have the same type car I had back then. Thanks for that info, so i will still have backup lights and safety switch! Now it makes sence why those wires are going to that solenoid on the intake which now i can remove knowing whats it,s function was. Hey give me credit I have owned mopars since i was 17 and im now 56 and went back to my first car
