changed from st300 to 350 turbo but?
Old Aug 21, 2011 | 03:28 PM
dartphil's Avatar
I changed me tranny from the old st300 to a 350 turbo on my 64 olds. But the 350 has no plug on it anyplace for the electrical plug for the backup lights and i guess the neutral safety switch. Do the newer ones work in a different way than the old cars do? Like maybe switched at the column? Other than that the tranny switch was no problem.
Old Aug 21, 2011 | 03:57 PM
Oldsmaniac's Avatar
Column shift auto had neutral switch and reverse light switch at base of steering column. Now that you have a 3 speed there will be an extra position on the PRNDL indicator.
Old Aug 21, 2011 | 06:37 PM
dartphil's Avatar
thanks so now i have to figure out how to make mine work. And about the extra gear for shifter im thinking of going with an aftermarket floor shifter that looks like a 4-speed. OH! duh,the new shifter should have something for the switch.
Old Aug 22, 2011 | 03:12 PM
Um, the ST300 didn't have those plugs on the trans either...
The only electrical plug on the ST300 was for the kickdown and the switch pitch torque converter. The TH350 doesn't use those. The neutral safety switch and the backup light switch were on the shifter and won't change when you change the trans.
Old Aug 24, 2011 | 02:47 PM
dartphil's Avatar
Thumbs up
Hey now don,t beat me down LOL, I am totally new to the Oldsmobile brand since I was 16 and now have the same type car I had back then. Thanks for that info, so i will still have backup lights and safety switch! Now it makes sence why those wires are going to that solenoid on the intake which now i can remove knowing whats it,s function was. Hey give me credit I have owned mopars since i was 17 and im now 56 and went back to my first car
Old Aug 25, 2011 | 09:47 AM
Not sure how what I wrote was a "beat down", but in any case, welcome.
MudEye
Apr 22, 2021 06:44 PM
80_cutlass
Mar 17, 2011 06:03 PM
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
