Tuning up a 5yr sitting Hydra-matic 4-S
Old Dec 13, 2010 | 02:26 PM
trackz man's Avatar
My son (13) and I are replacing engines from a 1963 88 to a 1963 Starfire. The transmission out of the 88 has been slipping real bad in 2nd gear plus... So, we have a transmission that was a runner or shifter, but has been sitting in the 88 trunk for over 5 years. What should we do to make sure the transmission will work and shift properly before we install into the Starfire- The original Starfire motor and trans have sat outside for over 30+ years-So that transmission is probably not a option?
Should we open pan-replace a filter? and fluid?. any other maintenance items???
Old Dec 17, 2010 | 10:36 AM
trackz man's Avatar
Maybe there is not any trans experts out there. LOL???
Old Dec 17, 2010 | 11:39 AM
Oldskeeper's Avatar
Hi trackz man, for mine 63-98 custom sport coupe all I did was a fluid change,filter,front and rear seal,that was in 94 and still works like a charm.
While the tranny is unbolted from the engine chech the dampening plate and make sure the springs are tight,if they are loose you will hear a rattling sound at idle from the vibration.
good luck
Steve
Old Dec 17, 2010 | 01:22 PM
rocketraider's Avatar
Oldsdruid
Make sure you have a filter before you drop the pan. Those filters have gotten hard to find and often expensive depending on who has them.
For Slim Jims, experts are few and far between. Most people who knew anything about them are retired or dead.
Old Dec 20, 2010 | 04:57 PM
trackz man's Avatar
oldskeeper and rocketraider-
Thanks for the advise- I have not been able to find a trans filter as of yet. Is there a proper way to clean the filter and re-use it???
Old Dec 20, 2010 | 08:53 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Here is a thread that covered this not long ago.
https://classicoldsmobile.com/forums...1964-88-a.html
Old Dec 21, 2010 | 10:09 AM
Oldskeeper's Avatar
I picked up a filter at a local tranny shop for one of my other cars and the filter came with a gasket as a kit,the filter was made by King filters.
Hope this helps
Steve
doc93
Nov 5, 2023 05:13 PM
stlbluesbrother
Dec 7, 2009 05:16 PM
Tony Daytona
Jan 5, 2009 12:16 PM
American Lead
Nov 16, 2008 04:10 PM
malatu
May 5, 2008 09:24 AM
