Dowl pins
Dowl pins
I need to pick up a set of offset dowel pins for my bellhousing install on the 455. I find 2-diameters .621 & .625. Which is correct for the 455? Its confusing the two diameters are listed
I use the Lakewood offset dowels, which are available in .007", .014" and .021" offset. Because they are a press fit, I drill them 17/64" and tap 5/16 x 18 thread so I can use a slide hammer to pull them out. That is how I remove the stock dowels from the block too.
