How to hook up cable to transmission
Old Feb 23, 2011 | 06:56 PM
theoldsrocket's Avatar
http://www.youtube.com/wa
TH350 how do i convert from column shift to floor shift. Also how will I put the brackets on the transmission please help?
Old Feb 23, 2011 | 10:26 PM
Aceshigh's Avatar
Since all A-bodies are damn near identical,
you can also use TeamChevelle and the GTO forums to find info like this.
http://www.chevelles.com/forums/showthread.php?t=50240
http://www.gtoforum.com/f50/column-s...shifter-19329/
Old Feb 24, 2011 | 05:27 AM
2blu442's Avatar
There are two brackets on the transmission, one attaches to the pan and holds the cable housing in place. The other is on the shifter bolt that rotates as the transmission goes through the gears. It is where the cable attaches. There should be several threads discussing this, try the search option and see what you find. If you still have questions I may be able to get more details for you this weekend. John
defiant1
Feb 4, 2020 08:53 PM
rootney
Jun 27, 2014 11:30 AM
dmberendsen
Apr 10, 2013 03:18 PM
projectheaven
Jan 8, 2012 09:17 AM
OLD SKL 69
May 10, 2007 04:10 PM
