'70 442 TH400 Kick down switch adjustment
Old Aug 24, 2011 | 09:12 PM
DRXOLDS's Avatar
Hello,
What is the correct way to adjust the kickdown switch on a '70 442 TH400. Seems like the barrel diameter of the switch is too small and you have to push way to hard on the gas pedal to get the car to down shift.
Any info would be helpful. I actual added a piece of gas line over the barrel of the switch to increase the diameter. I'm sure there's a better way.
Thanks !
DRXOLDS
Old Aug 24, 2011 | 10:47 PM
svnt442's Avatar
If I remember correctly you pull the switch all the way up (you'll feel it clicking) and then floor the pedal and that should adjust it properly. If you still have issues (like I do), you may need a replacement switch.
mcox8051
Jun 25, 2015 11:13 AM
66 Olznut
Apr 22, 2013 08:32 PM
oldspackrat
Aug 23, 2011 08:14 PM
salisbury99
Jul 5, 2008 05:26 PM
J&P Chassis
Dec 31, 2006 04:16 PM
