Rookie transmission question
Old May 16, 2011 | 07:11 AM
1971 Olds 442's Avatar
I just purchased my first classic, 71 442. I am not a mechanic and trying to learn as much as I can as I go. My 442 has the 455 in it. It seems like once I get around 50 mph plus it should kick into a higher gear. Is it at it's highest gear or is something wrong? Thanks
Old May 16, 2011 | 07:21 AM
InfoJunkie's Avatar
InfoJunkie
How many times does it shift between 0mph and 50mph?
Old May 16, 2011 | 07:51 AM
What 'Junkie said.
It's a 3-speed transmission. It should shift twice (1-2 and 2-3). Count the shifts.
"Mmmmmmmmm..BZMmmmmmmmmm..BZMmmmmmmmmmmmmmmmmmmmm. .."
(Like my transmission imitation? ?)
What's your rear-end ratio?
Old May 16, 2011 | 08:11 AM
If you have never driven a car with a 3speed auto, and moderate gearing, say 3:23's or 3:42's, it will seem like it needs another gear, but that is normal. What rpm's are you running?
Old May 16, 2011 | 08:39 AM
...it will seem like it needs another gear, but that is normal.
Let's be honest - It DOES need another gear. The manuals do, too (all 1:1 final drive).
They just weren't handing 'em out back then in American cars.
Old May 16, 2011 | 09:00 AM
The guys that were buying performance cars "back in the day" weren't looking for highway cruisers, but street performance...stoplight to stoplight, and usually did not have to commute to far to work, hence the stiff gears.
Old May 16, 2011 | 10:42 AM
1965cutlassragtop's Avatar
i thought "442" stood for 4 barrel carb, 4 speed trans, & 2 (dual) exhaust?? how can it be a 442 with a 3 speed tranny?? correct me if i'm wrong....
Old May 16, 2011 | 11:00 AM
droptopron's Avatar
delete
When it debuted in '64 that was the case but by the next year they were offering automatics with less than four fwd speeds.
Old May 16, 2011 | 11:08 AM
It's what's called "marketing" and "flexible definitions."
Old May 16, 2011 | 11:19 AM
okay, got it....thanks guys!!
Old May 16, 2011 | 04:27 PM
Thanks everyone for the clarification. It does shift twice so it sounds like I'm good to go.
Old May 16, 2011 | 04:36 PM
I have limited slip rear end with 3.40 ratio.
Old May 16, 2011 | 04:37 PM
What 'Junkie said.
I have a limited slip rear end with 3.40 ratio
rocket rookie
Oct 5, 2010 06:13 PM
rharule
Dec 29, 2009 08:32 PM
luckyman15
Jan 24, 2008 12:14 PM
putter
Aug 11, 2006 09:45 PM
