EEK!!! no likey this noise
Old Sep 14, 2011 | 02:02 PM
sicky olds's Avatar
NôôB
So i was driving home today from pt in the morning and i noticed my car making a funny noise....Finished driving it home and parked it but then when i went to go back outside and restart it... It started making a LOUD chirping noise, seems to be coming from the flywheel but it is so loud that it encases the whole engine bay and not sure where it is coming from. I then turned it off and had my roommate see if he could hear it and when i went to start it the starter did made that slow "i dont want to start for you" noise. When it finally started up it made the same "chirping" noise. Was closer in time together when it was in park or neutral also...
Any Ideas?
455 Ci/th400 combo
Old Sep 14, 2011 | 05:41 PM
Bill in NC's Avatar
Cracked flexplate near the crank??
Does the trans fluid still look good?
Old Sep 14, 2011 | 06:32 PM
firefrost gold's Avatar
starter gear not retracting and a bearing in the starter squawking?
Old Sep 14, 2011 | 06:38 PM
CQR's Avatar
CQR
Slow crank (like a real tight engine) and a loud chirp, sounds like a spun bearing.
Old Sep 14, 2011 | 06:51 PM
sicky olds's Avatar
NôôB
I did not want to hear that one.... Just got done rebuilding the damn thing....
Looked fine to me same with the fluid
Time to pull the starter... always start with the cheapest problem right?
Old Sep 14, 2011 | 07:08 PM
I seen this on two car's one a 70 gto judge and other a 351 Windsor that was a commercial air compressor . The gto squealed like hell and the widsor locked up thought we blew it up started to tear it down and found the problem
Good luck.
Old Sep 14, 2011 | 07:10 PM
442scotty's Avatar
distributor gear bottoming out in the block...thats what happened when mine was chirping..needed a gasket to bring it up a bit.
Old Sep 14, 2011 | 07:57 PM
sicky olds's Avatar
NôôB
http://www.youtube.com/watch?v=aVxsm2RMLhg
Here is the video of it running.
The weird thing is I have been daily driving the car for almost a month now and today is the first time i heard the problem...
Old Sep 14, 2011 | 08:31 PM
Lady72nRob71's Avatar
OUCh - that squalling hurt my ears in that vid!
If coming from the fron tof the engine, pull all the drive belts and run under a minute or two to rule out accessories.
Hope it is not the bearings!!!
Old Sep 14, 2011 | 08:33 PM
sicky olds's Avatar
NôôB
yeah it hurts my ears and my heart and maybe my bank book ><. Which sucks cause now both of my cars are in no driving condition....
Old Sep 14, 2011 | 10:55 PM
svnt442's Avatar
There was another guy with a sound similar to that and his ended up being bad bearingS. It was thought it might have been something with the water pump or the cam button on the timing cover, but it was rod bearings.
I hope yours is not so bad, but man that sounds AWFUL!
Old Sep 15, 2011 | 04:58 AM
CQR's Avatar
CQR
Ouch. I hope its not, but it sure sounds like it.
Old Sep 15, 2011 | 05:12 AM
Sicky,
I sure hope your engine builder knew about Olds engines. That doesn't sound good to me.
Old Sep 15, 2011 | 07:49 AM
Redog's Avatar
That really sounds like a bearing to me. If you just had the motor rebuilt, your engine builder should fix itatno charge to you
look up my vid on YouTube titled "307 with blown motor" I had a knock, then spin a bearing, then I shot the vid. I would post it up for you, nut I'm on my cell phone right now posting this
good luck
Old Sep 15, 2011 | 07:54 AM
CQR's Avatar
CQR
Here you go Redog.
http://www.youtube.com/watch?v=CO6BNhxlh1w
Old Sep 15, 2011 | 09:35 AM
sicky olds's Avatar
NôôB
Well... The guy who rebuilt the engine was me and a buddy in my garage... So can't ask for a free fix on that. Just seems weird cause I almost put 1k on the motor and you would think it wolff have happened before that? But the guy who machined it def did. He does everyones motor in the club
Old Sep 15, 2011 | 09:38 AM
sicky olds's Avatar
NôôB
Thee funny thing is I am not heating a knock. Just that damn squealing noise.
Old Sep 15, 2011 | 10:15 AM
rocketraider's Avatar
Oldsdruid
It may be the cellphone vid sound quality, but something sounds like it's knocking.
Are you seeing anything in the oil? Has it been changed since the rebuild and did you check to see if there was any metal in the filter?
Any align boring done? Crank turning? How did you set your bearing clearances?
Drop the flywheel cover and see if there's anything stupid going on in there as that's the easiest thing to check. A transmission bushing will raise hell like that too.
You DID put the galley plug with the hole in it where it could lube the timing chain, right? The other one at the back shouldn't affect anything as all it does is keep enough fresh oil flowing thru the galley to avoid sludging, but nothing is above suspicion.
Good luck, flyboy friend. I know you hate to hear all this.
Old Sep 15, 2011 | 01:55 PM
sicky olds's Avatar
NôôB
Just to be sure i took off the belts to the alternator and still making that noise. Funny thing is when i rev it the noise almost seems to go away.... Is that another sign of a spun bearing? But i still dont hear any knocking.... Going to drop the starter next and see if its sticking i guess
Old Sep 15, 2011 | 02:02 PM
CQR's Avatar
CQR
Drop the into a clean pan. Once its in the pan, stick a finger in and give it a stir. You'll see it if its a bearing.
sicky olds's Avatar
NôôB
Yes changed the oil but i havent drained it to see yet due to troubleshooting the easy parts first
Du whu? Yes crank is turning cause the motor runs? and to the 3rd question i repeat du whu?
Going to check that right now and get back to you, but how do i check a transmission bushing?
As far as i know everything was done correctly. The guys i did this with have rebuilt many olds engines
Thanks for the input guys and i would just like to remind you i am not TOO mechanically inclined here but trying my best
Old Sep 15, 2011 | 02:03 PM
sicky olds's Avatar
NôôB
drop what into a clean pan?
Old Sep 15, 2011 | 02:10 PM
stevengerard's Avatar
Yikes I thought my motor made funny noises, that sounds like a poodle got stuck under your car
CQR's Avatar
CQR
Sorry brain works faster than the fingers. Drop the oil.
Old Sep 15, 2011 | 02:15 PM
CQR's Avatar
CQR
Not good to hear. I don't care how much you trust your machine shop. Always plastigage your bottom end. Everyone can have an off day. I've even had mis-boxed bearings .040 in a .030 box(1 out of 8 packages)
Old Sep 15, 2011 | 02:38 PM
sicky olds's Avatar
NôôB
I THINK I FOUND IT!!!!! pics posted soon on what you guys think... But i think somehow my flywheel is rubbing against the transmission housing!!!!
Old Sep 15, 2011 | 02:47 PM
RAMBOW's Avatar
Ben
clutch disk on backwards... springs are hitting the flywheel bolts
Old Sep 15, 2011 | 02:50 PM
sicky olds's Avatar
NôôB
Do Automatics have a clutch disk also? And wouldnt they be doing that from right when i first started running it?
Old Sep 15, 2011 | 03:05 PM
442scotty's Avatar
Loose flywheel bolts? loose torque converter bolts should clunk and rattle
Old Sep 15, 2011 | 03:28 PM
CQR's Avatar
CQR
Hopefully just a broken flexplate.
Old Sep 15, 2011 | 03:55 PM
  #31
sicky olds's Avatar
NôôB
Seems like it is something with the distributor. The bolt that holds it down was loose, now just trying to pinpoint what it might be on it. talking to a buddy to see if i can fix it. might be right though 442Scotty
Old Sep 16, 2011 | 08:06 PM
  #32
sicky olds's Avatar
NôôB
Can i get more explanation on this one please? Was talking to a guy and he said that made no sense to him so can i get more explanation on this one please?
Old Sep 16, 2011 | 08:16 PM
  #33
I have my fingers crossed for an easy fix...
Old Sep 17, 2011 | 07:24 AM
  #34
442scotty's Avatar
I purchased my distributor through DUI...They did an awesome job setting it up but it screeched as soon as it was installed...I took it out and found that the casting was too long causing it to bottom out in the block so I made up a nylon gasket to go between the unit and the intake which was edelbrock. It raised the unit up just enough and no more screeching. I could have ground the bottom of the gear I suppose to take some meat off and do it that way.
Old Sep 25, 2011 | 04:18 PM
  #35
sicky olds's Avatar
NôôB
Doesnt seem to be the distributor. no excess wear in the distributor or funkiness. Also pulled up the valve cover jsut to see and nothing looked bad to me... We are thinking it might be the Cam or something with that, reason for this it almost sounds to be in interval and it also seems to be every other rotation it makes that noise...
Old Sep 25, 2011 | 04:59 PM
  #36
coppercutlass's Avatar
Chevy budget Olds powered
i hear some knocking but it could be bad video quality try to but a cheap mechanics stethescope or loud screwdriver to isolate the sound in the bottom end you put the screwdriver to the block and an ear on one end it works beleive it or not hope its something simple
Old Sep 25, 2011 | 08:13 PM
  #37
Bill in NC's Avatar
Did you pull the converter loose from the flywheel and push it into the trans and start it to see if the noise changes? That noise really sounds external from the video, and I would suspect the cause to be in that area.
Old Sep 25, 2011 | 08:16 PM
  #38
sicky olds's Avatar
NôôB
will have to try that but the wierd thing is that it "stalls" as soon as i stop giving it gas now...
Old Sep 25, 2011 | 08:23 PM
  #39
CQR's Avatar
CQR
Ouch. That could mean its getting ready to lock up tight. Have you dumped the oil yet? If not, I would highly recommend doing that before you start it anymore. If it is a spun bearing, your only causing more damage by starting it. My .02
Old Sep 25, 2011 | 08:25 PM
  #40
sicky olds's Avatar
NôôB
havent dropped the oil yet. will do that this week when i got the time
and only starting it on rare occasions. We might think it has to do with a cam bearing or something...
