torque converter help
Old Apr 25, 2011 | 01:02 AM
rayfrausto's Avatar
I have a 77 cutlass supreme with a 350 engine. So the car makes a little noise like sounds like a wobble(seems to be coming from flyweel/tc area). The engine dosent shake to bad but it dose slightly when you pop the hood u can see the motor shake bits its not really bad. So we looked at the flyweel to see if it was bent or rubbing on something everything good. Notice that on the torque converter there are small weights and we notice one to be loose it is like half way on half way off. So this can be the problem??? If si how to fix
Olds luvr
Apr 10, 2014 05:51 PM
Stevec
Apr 20, 2012 05:46 AM
bigwillystyle
Nov 13, 2010 11:52 AM
SPEEDROCKET
Dec 18, 2007 06:35 PM
Surfrat67
May 14, 2006 03:42 PM
