torque converter help
Old Nov 12, 2010 | 10:07 PM
bigwillystyle's Avatar
new user
I just had my transmission rebuilt along with a rebuilt Torque Converter. When the TC is seated all the way against the pump, how much distance should be between the TC mounting bolts and the Flexplate?
With the transmission bellhousing all bolted up to the engine block and the TC is seated all of the way up against the pump there is approximately 1/4 inch of space.
Old Nov 13, 2010 | 03:12 AM
Rickman48's Avatar
Sounds a little tight, maybe on the low side of recommended clearance.
Are you sure it's seated?
Shoud fit into the notches on the pump - as you turn it, you'll feel it 'seat' - and go in about an inch.
I usually put a film of wheel bearing grease on the shaft to avoid wasting the seal, too!
Old Nov 13, 2010 | 11:52 AM
If you can spin the converter without it dragging on the flexplate before you bolt it up, you're fine. Typically with the converter up against the pump you can barely get a finger in between the converter and the inside of the bellhousing
Olds luvr
Apr 10, 2014 05:51 PM
Stevec
Apr 20, 2012 05:46 AM
rayfrausto
Apr 25, 2011 01:02 AM
SPEEDROCKET
Dec 18, 2007 06:35 PM
Surfrat67
May 14, 2006 03:42 PM
