wont shift out of first
I have a 350 hydra-matic. Just recently, it won't shift out of first. It will go in reverse. I replaced the vacuum modulater and the hose going to the modulator. I even put a larger diameter hose on. Still wont shift out of first. What can I check next?
Your local transmission shop, for a price!!
Could be a broken sprag, stuck piston in the valve body, even a stuck check-valve, but if you're unfamiliar with automatics, you're at their mercy!
Sure, you coud order one from B+M, or another big-name trans builder, and pay to install it, but ask your local guy for a shift kit, and a one-step-up converter, and you should be around a grand with a year warranty.
Don't 'downshift' and it'll last longer!
Verify that you have manifold vacuum at the modulator before you spend any money on parts or repairs. Also, will the trans upshift if you keep accelerating? If the modulator (or vacuum source) is bad, the trans should upshift from first to second at around 45-55 MPH.
