PDA
View Full Version : Transmission
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13
  1. Doing the swap
  2. Crossmember location for th350/400 and 200r4
  3. Torque converter issues....maybe????
  4. TH400 ID tag is NOT numbers matching on my car!
  5. Please help with issues with my newly rebuilt 200-4R
  6. Speedometer incorrect
  7. TH350 Problems
  8. Rubber with steel core Transmission Pan Gasket for TH350
  9. 200-4r rebuild
  10. Turbo 400 cable bracket
  11. wanted, picture reference on 1964 88 (or perhaps 1963) transmission mounting
  12. Need Help With 1968 Muncie M20 Shifter
  13. can this be the transmission
  14. 200-4r lockup control
  15. Hydraulic Throwout Bearing - No Clearance
  16. TH350 Accessories
  17. M21 stuck in second
  18. Do I Even Need to Do This?
  19. Okay, I have another transmission question
  20. Atf?
  21. Tooling-up for trans swap
  22. Clutch Recommendation
  23. Pilot bushing question.
  24. shift shaft woes
  25. 1973 Cutlass 442 & 200r4
  26. 72 Cutlass Supreme transmission question
  27. 1955 Olds Hydramatic
  28. Clutch fork
  29. Transmission Identification
  30. Transmission information
  31. Th400 stall convertor
  32. Torque converter dimension
  33. 1969 Cutlass Backdrive linkage Question?
  34. th400 transmission modulator
  35. maaaaan
  36. 69 cutlass starting with lever on D or R
  37. Torque converter lockup question
  38. 700R4 shifter detent and transmission arm
  39. Transmission Vent Tube
  40. Transmission swap
  41. Wrong shift cable bracket
  42. Torque converter
  43. Are These The Right Parts To Convert 70 Cutlass To Manual Transmission--PICS included
  44. Remove clamp holding transmission cooler lines
  45. Rant!
  46. After market shifter cable
  47. STIFF clutch pedal feel
  48. Rebuilding roto-5, what broke in yours? 1962 F85
  49. Cross Member interchange
  50. 1964 Cutlass Conv Auto to Manual
  51. Conversion from Automatic to Manual Transmission---Shifter Hump Placement?
  52. Help...replacement transmission slip yoke, M21
  53. Transmission removal from under car vs pulling engine/trans as whole
  54. Off the shelf rebuilt TH400? Brands to avoid and ones to top the list
  55. Trans Cooler Lines
  56. Any recommendations for TH400 or...
  57. Which One Fits: M20 M21 M22
  58. Muncie speedo gears
  59. Looking for Olds 4GC and Slim Jim Expert in DFW
  60. Tell me about these Jetaway transmissions
  61. muncie quest
  62. 1972 TH350 need input
  63. TH 400 Vent tube
  64. Muncies
  65. Torque converter to flex plate
  66. 200-4R swap questions
  67. '69 Jetaway detent Solenoid repacement
  68. ck performance transmission rebuild kits
  69. turbo 350 speedo gears
  70. Judy's 1987 cutlass transmission problems,help!
  71. what kind of 4 speed?
  72. Switch Pitch 400
  73. switch pitch tranz controller
  74. speedo cable
  75. 69 cutlass post sedan options
  76. Backup light sending unit on TH350
  77. Jetaway-350 Swap ?
  78. 1972 Cutlass LGT 700 5 Speed Conversion from Auto - Shifter Question
  79. Fly wheel resurface and clutch fork
  80. 68 cutlass / 442
  81. 68 cutlass S/ 442
  82. Service cases - how are they viewed in the collector car community?
  83. 82 cutlass pouring transmission fluid out of front seal
  84. 1973 old cutlass supreme 442 options
  85. detent switch
  86. broken shifter. how to unlock TH350 transmission
  87. Clutch linkage
  88. ? about Tag on Muncie 4spd Transmissions
  89. Input sought - M22 Rockcrusher
  90. Transmission oil cooler
  91. Shifting High??
  92. Slim Jim Hydramatic
  93. Leaking Jetaway - '65 Vista Cruiser
  94. 5 speed swap
  95. 1964 Oldsmobile Jetstar I
  96. 1970 turbo 350 kickdown cable?
  97. '71 TH 400 not shifting
  98. TH 400 Problem
  99. 375C Hydramatic needs help, maybe
  100. 1949 Hydramatic
  101. Which rebuild kit for turbo 400?
  102. 61 olds 88
  103. 4L80E in a 65 Olds 98
  104. Leaking fluid
  105. 72 TH350 Pressure switch
  106. Crossmember Needed
  107. TH 350 SWAP FOR 200 R4 - Pics?
  108. length of shifter cable 70 cutlass
  109. Transmission speedometer housing identification
  110. automatic shifter brought from e bay
  111. Speedo Driven Gear Install - 68 Cutlass S / Jetaway Trans
  112. TH400 in '87 Cutlass with 455
  113. Overfilled transmission
  114. th350 swap
  115. M-20 trans leaking.
  116. 1966 Olds 442 help
  117. Th425
  118. Trans "screech" when in reverse
  119. Rebuild kit for a 62 dynamic transmission
  120. Is a 61-64 slim Jim the same?
  121. M10 or 3/8" ? - 1978 TH350 Trans Mount to Trans
  122. Sealant for trans gasket
  123. transmission code
  124. Is it major work to replace the seal
  125. Flywheel advice
  126. Must-read HMN article ref Switch Pitch Trans
  127. Kick down switch Super Turbine
  128. Racing Jetaway?
  129. 1972 cutlass makes grinding noise when it shifts to second
  130. Choosing a clutch
  131. Clutch fork issues
  132. Shift kit in 71 toronado
  133. 68 cutlass supreme Tranny kick down
  134. M 21 Identification Help
  135. Clutch Adjustment
  136. TH350 broke?
  137. Shifter
  138. Jetaway not working right?
  139. Solid build specs for 200-4R?
  140. 2004r driveshaft length
  141. Erratic shifting/Cruise
  142. 1958 transmission help
  143. Transmission help
  144. TH350 detent cable replacement help needed
  145. Curious trans problem
  146. 1984 hurst olds with a dead tcc
  147. 1968 versions of TH400 - diffs?
  148. 200 r4 lock up
  149. what do you guys think?
  150. 4L80E Controller
  151. '68 OW trans stamp color and dipstick tube
  152. Roto-hydramatic wont downshift cold
  153. Muncie 4-speed will not go all the way in?
  154. 4L80E w/new valve body
  155. 200-4r rebuild
  156. 66 toronado transmission problem
  157. Swapping in a 700R4 in a 63 Starfire
  158. Question Auto to Legend 5 speed
  159. TR3650 questions
  160. Tranny crossover modifed
  161. 1956 Rocket 88 - Hydra-Matic Dual Range Transmission - No forward gears??
  162. '65 F85 tranny leak
  163. 62 Cutlass Trans Swap
  164. 2004R in a '71 Delta 88
  165. Prebent transmission cooler lines
  166. M22 rebuilt and leaking in front
  167. TH350 vs TH400 Shift Lever
  168. Any one dealt with Silver Sport
  169. Mondello Th-400
  170. Silver Sport vs. Hurst Drive Line
  171. Trans leak
  172. What a Dipstick (transmission)?
  173. TH350 downshift from 3 to 2 @ WOT
  174. TH400 finishing nail?
  175. Identifying TH400
  176. TH350 hesitates coming out of park
  177. Seized drain/fill plug
  178. Torque converter recommendation- '68 442 stock
  179. How do you install transmission lines?
  180. TH350 Thrust problem
  181. TH400 linkage leak
  182. TH350 Speedometer Gear "0" Ring Source?
  183. Th400 reverse acts like brake is on
  184. 1968 442 TH400 crossmember location- aftmost
  185. Won't go in gear
  186. 72 442 steering column linkage
  187. Converter mounting bracket hits the flywheel balanc weight.
  188. torqe converter
  189. Skylark Rearend in Cutlass - Pros/Cons?
  190. TH350 "kickdown"
  191. B&M 30262 shift improver kit
  192. 1967 Delmont 88 Clutch Pedal & Master Cyl Installation
  193. Need RotoHydromatic 5 TV tool
  194. Need RotoHydromatic 5 TV tool
  195. 2004R valve bodies
  196. Hydra-matic Tools
  197. 200 r4 lock up kit
  198. Th400 with short tail, what driveshaft to use..
  199. Hydraulic Clutch Master and Slave Cylinder and Progress Report
  200. console shift hole
  201. th 200r4 shift kit
  202. 70 442 Manual Transmission Install Help Needed
  203. ST300 Dipstick Measurement
  204. what could have happened.
  205. Linkage adjustment issue
  206. 1962 Oldsmobile F-85 Transmision swap?
  207. Which Transmission vendor?
  208. Overfilled Tranny
  209. 83 h/o
  210. Monster Transmision?
  211. TH350 leak
  212. General Motors Controlled Coupling Transmission Service Manual
  213. 83 H/O Torque Converter
  214. 71 Speedo. off by 50mph
  215. 70 442 Pilot Bushing Problem
  216. Tranny swap??
  217. American Powertrain - 'TKO 600 Perfect Fit Kit'
  218. 91 Trofeo with 4T60E Not shifting past 2nd
  219. Tranny Pouring Out Fluid
  220. 55 manual
  221. TH350 rebuilt, now shift points are off
  222. I need advice.. Switch my switch pitch
  223. Olds 455 Bellhousing
  224. 71 Cutlass Manual Transmission Conversion
  225. Transmission Identifacation
  226. About To Give UP!
  227. Header/ Clutch Z Bar Conflict
  228. 85 Olds Delta 88 Tranny crapped out
  229. TH350 died
  230. Switch Pitch Pump Gasket
  231. 350 olds in a chevy pickup
  232. 83 Olds Custom cruiser wagon.
  233. Decode Super Turbine 400
  234. What type of tranny is this? (turbo hydramatic)
  235. 72" Cutlass TH350 to 200R4
  236. Advice on 71 Cutlass Transmission change/swap
  237. Monster transmission
  238. Correct '68 trans pan
  239. clutch disc specs 55 olds
  240. Leaking gasket
  241. 55 Olds super 88 manual trans clutch set
  242. Help,need olds hydromatic identification so I can sell it
  243. Can anyone Identify this Borg Warner Super T-10
  244. 67 Cutlass Transmission
  245. 71 Cutlass replacing 350 trans - which one??
  246. Trans cooler help
  247. 1941 hydramatic
  248. Muncie casting and stamping question
  249. TH400 Gear Noise from transmission sound
  250. TH400 Dual Gate stays in drive
