TH 400 Problem
Old Oct 27, 2015 | 08:34 PM
CrazedCountryRebel's Avatar
TalksToToads
TH 400 Problem
Hi guys, I was wondering if you could help me with something. The other day my car wasn't shifting right, so I checked the fluid and it was low, it took a quart and a half to fill it. I still had some trouble with it today, and I'm starting to wonder if it has anything to do with the high pitched whining sound it's making. It used to go away after a bit, but now it does it pretty much all the time. Could this be a sign of a pump or torque converter going out?
(68 Delta 88,455,th400)
Old Oct 27, 2015 | 08:55 PM
Its a sign it needs at least a filter change. If the fluid is not a pretty red color and smells burnt its a sign it needs more than that.
Old Oct 27, 2015 | 08:58 PM
TalksToToads
Before I added to it, I noticed the color was very dull.
Old Oct 27, 2015 | 09:00 PM
The whine generally means its having trouble pulling fluid through the pump.
Old Oct 27, 2015 | 09:10 PM
TalksToToads
Thanks for the tip. I'll take it in and get the fluid/filter changed
chrisneu68olds
Dec 30, 2011 10:17 AM
dgreen
Nov 6, 2011 09:40 AM
Gearhead442
Jan 27, 2011 03:03 AM
sbFALL63
Jan 23, 2011 09:01 AM
sbFALL63
May 28, 2010 05:45 AM
