Turbo 400 cable bracket
Guys:
I am looking for an OEM bracket that mounts on the transmission pan that holds the cable for a 68-69 Cutlass w/ a Turbo 400 trans, the repop ones I looked at in the catalogs seem a generic looking. If anyone has had good luck with an aftermarket piece, I would appreciate some information about it.
Thanks, Ron
Thanks, Ron
Hello:
Have you tried this bracket? There are a couple different versions out there, but hate to go thru the headache of ordering one and finding out that does not work or fit correctly.
Thanks, Ron
Thanks, Ron
Bruce, the bracket fit but is slightly different from the stock one on '69.The one recommendation I would have is slot the holes on the bracket so you can move it back and forth on the tranny. Especially if you are using a dual gate. This will give adjustment for park and first gear.
Tim
Tim
