Turbo 400 cable bracket
Old May 8, 2016 | 03:38 AM
RonFX's Avatar
Guys:
I am looking for an OEM bracket that mounts on the transmission pan that holds the cable for a 68-69 Cutlass w/ a Turbo 400 trans, the repop ones I looked at in the catalogs seem a generic looking. If anyone has had good luck with an aftermarket piece, I would appreciate some information about it.
Thanks, Ron
Old May 8, 2016 | 04:35 AM
timholliday's Avatar
Member
http://www.ebay.com/itm/69-70-71-72-...item5ad1362143
Old May 9, 2016 | 02:30 PM
RonFX's Avatar
Hello:
Have you tried this bracket? There are a couple different versions out there, but hate to go thru the headache of ordering one and finding out that does not work or fit correctly.
Thanks, Ron
Old May 9, 2016 | 07:40 PM
Member
The fit was fine on the Turbo 400. I have not physically installed the cable yet but everything appeared to line up OK.
Old Sep 22, 2016 | 07:24 PM
servexcell's Avatar
Tim how did it go was the bracket the right one. i am doing the same on my 68 Cutlass Convert. Installing a 400/400
I am going to get a shifter kit from shifterworks. How did you install the kick down switch,
Bruce
Old Sep 23, 2016 | 06:14 AM
Member
Bruce, the bracket fit but is slightly different from the stock one on '69.The one recommendation I would have is slot the holes on the bracket so you can move it back and forth on the tranny. Especially if you are using a dual gate. This will give adjustment for park and first gear.
Tim
busman442
Nov 16, 2013 03:20 AM
72 Olds Project
Oct 18, 2013 12:48 PM
leadfoot067
Jan 26, 2010 08:09 AM
Liegekiller
May 30, 2009 05:31 PM
