1962 Oldsmobile F-85 Transmision swap?
Old Apr 5, 2015 | 12:28 AM
jbl acoustics's Avatar
Hello,
I am having issues with both of my transmissions on my 1962 olds f85. Does anyone have any advice on a different transmission i can use? Thanks for all your help!
Best Regards,
Jason
Old Apr 5, 2015 | 07:50 AM
Originally Posted by jbl acoustics
Hello,
Best Regards,
Jason
This comes up a lot. Unfortunately, the 215 has a unique bellhousing and the 61-63 cars have tiny tunnels. The Rotohydramatic5 is a very small transmission. D&D sells an adapter plate to let you use a modern GM automatic, but you'll need to cut and weld the tunnel as well as build a custom driveshaft. Or, you can convert to a manual trans. The T5 is a nice swap into these cars.
Old Apr 5, 2015 | 09:14 AM
Thank You
Thank you Joe!So it would be easier to do a manual transmission than a TH350? That would be great! I prefer Manual. All the help is greatly appreciated!
Old Apr 5, 2015 | 12:03 PM
Well, if you can source a complete factory setup, the 4spd is a bolt-in. Alternately, D&D sells new aftermarket bellhousings. Depending on which T5 you select, you may or may not need an adapter plate, which they also sell. This bellhousing will work with the stock clutch linkage or with a hydraulic TOB.
zekecut70
Mar 25, 2015 10:04 AM
cdoering
Oct 2, 2013 11:38 AM
442Fred
Sep 18, 2013 05:43 AM
cdoering
Jul 9, 2013 03:09 PM
dyter19
Aug 19, 2012 05:42 AM
