Overfilled Tranny
Overfilled Tranny
OK guys so I did a big bone headed thing....I over filled the tranny on the 442 by about 2 quarts. I was adding out of a gallon jug and knew I only needed to add about 2 quarts but when the 2 quart mark came up i wasn't thinking and just kept adding. My question is without dropping the drainless pan how can I pull those 2 quarts out. My first idea was to go get some clertubing from the hardware store alone with a siphon pump and try and pump out the 2 quarts. What are your thoughts. Thanks guys.
That's a good idea because i have been in need to a fluid transfer tool. Pouring used motor oil sometimes gets messy if you don't hit the hole haha
What Eric said. A suction gun is a staple tool. Just purchase some hose and suck away. Next time you have the pan down(as trans fluid should be changed at regular intervals) why not install a drain plug kit or purchase a pan with the drain in it. Makes trans servicing a snap. Not to mention much neater.
Yeah our plan is to purchase a larger finned aluminum pan with drain plug at around 500 miles cauee our tranny builder suggested we should change it then. It gets pretty hot here in the summers (100°-110°) so the bigger pan with calling fins should help keep it cooler.
<jdhideaway@aol.com>
Brakes/Hydraulic Systems
Mar 31, 2005 08:15 PM
