View Full Version : Transmission
Pages :
12]
- 700r4 coversion into 64 Starfire with 394... PICS!
- PATC Products
- th350 question
- whats the difference in these th400's???
- TH400 pump seal size????
- 61 transmission
- vacuumm hoses
- 2 flywheels-which one 62 Cutlass 215v8
- Aut transmission issues
- where does the filler/dipstick tube usually locate on 67 TH400?
- shiftworks kit or aftermarket shifter in 64-66 auto console
- Half-moon shifter linkage
- Trans Problem... help!
- 200-4Rtransmission case paint
- 75 Turbo 400 in 65 Jetstar 1
- no kickdown on 400
- TV Cable Adjustment
- Turbo 400 trans from a 73 delta 88...
- 2speed wont shift out of the blue
- Part name and part number
- Tranny shifting problem
- what are my tranny options mating to my 394
- stock torgue converter
- 1955 - 88, How Difficult is it to remove speedometer?
- Ideas where to get a 4 speed
- Transmissioin coolant lines
- Transmission Oil Change - Newbie
- 400 / 455 Flexplate same????
- Thanks / Transmission pan leak
- Pics request
- Seal at speedo cable input on TH400?
- 400 turbo tranny ?????
- 61 Slim Jim in and out lines
- B&M TH350 separator plate
- what tranneys fit a 1964 Dinamic 88 convertable with a 394?
- having issuses with trans
- Rear Transmission Seal
- HELP! on a 1976 TH400
- '52?? Hydramatic question
- 64 Cutlass No Low Gear Help!
- New member with a '64 Jetaway problem
- TH400-How many leak points do I need to check?
- 69 cutlass clutch and shifter issue
- 200r4 question
- 200-4R and 455
- muncie number's
- transmission fluid capacity
- Mystery Turbo 400?
- Same Tranny's?
- speedometer housing
- Can I Rebuild a My Transmission
- transmission leak
- Torque converter
- noise from th350 trans ?
- trans making whining noise ?
- How do I remove the front seal on a TH350?
- Mounting an transmission cooler
- transmission Question
- what is the location of vaccum modulator valve?
- Question for a 65 cutlass f85 transmission
- Just got a couple 200-4r's
- want to buy Turbo 350 or Turbo 400
- T-56 6-speed will it bolt up??
- Flywheel Inspection Cover TH350
- Pivot ball on 455 FA block
- change speedo gear? TH400, much trouble?
- 200-4R transmission troubles.
- trying to identify a TH400.
- Hurst duel gate shifter question.
- 66 cutlass won't shift
- 700r4 in a 71 convertible supreme
- How to remove hurst shifter handle (66 manual tranny)
- Installing my Kilduff ratchet shifter
- TH400 For the 394
- Torque converter opinions needed
- 65 F-85 floor shifter. What year will work
- Jetaway worth?
- Transmission Cooler Routing
- tranny swap and rear end ratio
- What cars carry a thm350 with a 6 inch tailshaft?
- TH400 for dummies please
- 700R4 in '62 Starfire
- turbo 400 i.d. tags
- Problem using old torque convertor?
- st-300
- Dual Gate conversion to 4 speed trans
- 86 cutlass
- Information for installing a Dual Gate
- TH 200 4R TRANNY SWAP HELP!!!
- another slim jim thread woo hooooo
- 4spd interchange
- dimensions of slim jim?
- Dual Gate to 200R4
- 80s deltaa trans swap.
- 1971 transmission 350
- 69 442 with T-10 Trans
- Swapping a ST300 for a th400
- THM375 info and opinions wanted
- What tranny is this
- Does anyone 'rebuild' kickdown switch?
- Fluid capacity
- tranny cooler
- TH400? Kickdown? 67-442
- Neutral Safety Switch -67 floor shift
- After-market floor shifter/factory console??
- Hydramatic Transmission Disaster
- Turbo 400 rebuild help
- looking for an extension housing,roto-hydramatic 5,'63Cutlass
- fitting leak
- 1966 M/T Shifter boot Where to buy?
- transmission proplem
- T-5 swap
- t-5 swap
- 4 speed shifter question
- Drive train clunk
- Pain in the Ass problem that confuses me
- Proper Rigging
- Kick Down Cable?
- more help!pans off,now what?A.T.roto-5
- help!i dont want to rebuild!maybe quick fix?
- 1961 slim jim rebuilder
- Kickdown Cable??
- 200 4r upgrade kit
- TH400 Leaking Fluid
- th350 upgrade
- troubles w/my 1964 hydramatic
- Converting from TH400 to 700R4
- Dual gate issue
- tranny mounts
- 1970 Auto Transmission Cooler
- Switch Pitch converter
- t56 durability
- TH350 identity
- TH400 GTO to Cutlass question
- TH350 removal advice...asap
- Rebuilding a 1955 Hydramatic
- Electronic Shift Transmission
- powerglide?
- crossmembers
- will a 455 blot up to a 350 trans
- Trans rebuild
- olds vs chevy
- th350 kickdown cable
- Tip of the day
- 1955 Olds Hydra, options? other year autos swaps??
- Rocket
- would this match up with my 455
- tried under search
- 200-4R shift kit question
- Coulmn shift to floor shift
- Flexible trans cooler lines
- Kickdown cabel bolt size?
- TCS question
- Gearvendors fitment
- Late Shifting Problems
- Drivetrain options
- 4l60E behind my toro engine
- Is the TH 350 working properly
- Jetaway dipstick help
- trans help please!
- oldsmobile 2 speed powerglide rebuild
- Adapters
- Need Help With Trans Filter
- What Trans.
- Did I screw up my TH350?
- Engine Chuggles when stopping
- Where's my bell housing?
- Trans-cooler lines for Slim Jim '61 vs. '62 Starfire
- Transmission questions
- TH 350 fluid problem
- TH 350 rebuild advice
- dualgate linkage
- Switch-pitch in a 64 Cutlass: Worth it?
- '64 Turbo-Hydramaitc into a '63 Super 88
- TH 400 trans locked
- unicase th350
- Need Parts 55 Old's 98
- 54 Olds 88, Hydro
- 1964 Oldsmobile Service Manual - Vol. 2 Roto-Hydramatic
- Slim Jim filter?
- 84 Hurst transmission trouble
- Transmission type
- TH-400 Vaccum Modulator
- 2nd gear start in 50 Olds 98
- M20 whine
- TCI's 350 behind a 330
- 66 clutch linkage problems
- hesitating tran
- th400 stuck in foward gear
- th 350 linkage
- NEED HELP !!!
- jetaway
- timing chain
- getting to higher rpm in Drive
- Dual Gate A/T Shifter
- hydramatic v.s jetaway
- Stock 1970 442 W-30 Torque Converter
- need help with part numbers
- Lockup converter control options
- What is this???
- 57 Olds 4 speed auto I dropped it, help
- Need advice to get bell housing bolts out.
- 394 Oldsmobile - Tranmission Swap
- M22 / 350
- Help decoding my TH 400
- th400 kickdown
- 59 dynamic 88 trans questions
- Trany work and B&M shift kit
- Dual Gate adaptation to the TH-700-R4
- Help me identify Transmission
- transmission mishap
- Transmisson cooling lines
- Proper use of the Hurst Dual Gate Shifter
- No Reverse and seems to not shift to passing gear
- vacuum modulator
- Delta88 Transmission Question
- 1965 delta 88
- 4 to 5 speed conversion? 1966 442
- speedometer calibration
- M21 4-speed Shift Knob Types
- 1957 Jet a way trans how good are they???
- accumulator cover leak
- Overdrive tranny
- 63 slimjim to a TH350?
- Why would my 69 442 slip slightly in first
- 67/69 Floor Shifter Cable
- Column Shift to Floor Shift
- 1955 Oldsmobile 98 Holiday Transmission Problems
- 2004r Conversion
- What is a Slim-Jim
- 55 Super 88 - automatic shift points Hydra-Matic
- Swing set?
- info about transmission pans
- weird th350 problem???????
- four speed
- 61" slim jim floor shifter--Need ideas
- AT SHIFTER
- transmission automatic to manual
- '89 Olds "clunks" when put in gear
- converter 8, 9, 9.5 10" ???
- F-85 drive plate
- HELP CANT FIND
- gear shifting probs slim jim
- Tranny fluid coming out of kick-down cable inlet
- floor shifter question, 71 cutlass
- Need help to identify transmission
- Wiring up my floor shifter
- tranny fuild comming through the center of the yoke
- Which 3-speed manual gearbox in my -68 455 Delmont 88?
