Turbo 400 rebuild help
Old Mar 28, 2009 | 07:59 AM
ziff396's Avatar
I am in the process of rebuilding my turbo 400 this weekend and need some help. When I removed the valve body, and began disassembly, There is NO spring in the 1-2 accumulator (kickdown)! I went to compress it to remove the clip and found no tension, so I removed the clip to find no spring.
Is there a reason someone may have removed it? I was hoping to have this done today!
Thanks for any help.
Kevin
Old Mar 28, 2009 | 12:32 PM
jaysun's Avatar
ate glue as a child
Maybee the previous owner installed a shift kit? I think the b &m kit has you remove that spring.
/not an expert on trannys just know a few things.
good luck
Jason
matviar
Feb 26, 2012 11:05 AM
80_cutlass
Mar 17, 2011 06:03 PM
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
