TH 400 trans locked
Old Oct 15, 2008 | 05:39 PM
hussy250f's Avatar
TH 400 trans locked
I had a 400 trans in my garage for a few years now and I am going to swap it with friend for a 700r4 with a bad case of cooked clutches for another project.
Problem is the 400 is stuck in what I assume is forward gears no matter where the selector shaft is positioned other than PARK.
The output shaft will only spin in 1 direction in any gear including neutral. The PARK position seems OK.
The trans sat for a few years in a garage, but was working fine when removed from the previous vehicle.
It makes a definite mechanical "bottoming" noise when you attempt to spin it the other way.
Maybe just stuck clutches or a band from sitting?
Thanks for any input.
Old Oct 16, 2008 | 08:01 AM
If you've checked all of the obvious stuff (linkage, fluid level, etc.), I would say that you have an internal problem. The TH 400 uses a band to hold the ring of the sun and planetary gear set for reverse. Perhaps this band isn't engaging or is bad.
Old Oct 16, 2008 | 02:54 PM
88 coupe's Avatar
Junior Member
Originally Posted by Olds64
........ linkage, fluid level, etc ........
Hard to do, when the trans is not in the car.
........ Perhaps this band isn't engaging ........
Not possible for that to happen without pressure in the system. Pressure, that is supplied by the pump when it is turned by the engine.
I see one, or both, of the sprague (one way) clutches as a possibility.
Talk to your local trans rebuilder to find out for sure.
Norm
Old Oct 16, 2008 | 03:13 PM
A very high possibility. Alternatively, moisture (condensation or worse) has gotten inside the case and rusted parts together. Either way, the trans needs to come apart.
For complete correctness, it's a sprag clutch.
Old Oct 16, 2008 | 03:48 PM
88 coupe's Avatar
Junior Member
........ it's a sprag clutch.
Yes it is. My spalshikr should have caught that.
Norm
Old Oct 19, 2008 | 06:05 PM
hussy250f's Avatar
Thanks for the suggestions, I'm thinking the forward or intermediate clutch is frozen since the output shaft does turn in 1 direction.
I guess I'll be tearing the trans down for an exploratory looksie.
Thanks again guys.
Old Nov 10, 2008 | 01:27 AM
RoaringRelic's Avatar
When you say "spin" do you mean turn freely by hand? It is normal for a turbo 400 to turn in one direction easily and the other very diffucult. This is because the reaction carrier is fighting with the low sprag, low roller after '70. If you have the transmission output yoke handy it will turn both ways but one will be harder.
Muskrat
Alero
15
Jan 24, 2010 08:48 PM
88 coupe
Jul 6, 2009 11:15 PM
Warhead
Jul 4, 2009 09:34 PM
Tangovino
Brakes/Hydraulic Systems
18
May 27, 2009 02:38 PM
ragtop442
Apr 3, 2008 06:48 PM
