th350 question
th350 question
Hi,
i have a th350 transmission that is acting up... when i put it in drive it shifts right into it and drives fine, the same with reverse, but when i start driving it wont shift out of first.. i mean it pulls so strong and runs really good but it wont shift i dont think.. the car will keep accelerating to the point where the rpms get high and i let off the gas, at this point i can hear the car decelerating through my exhaust and when the rpms get low enough i give it more gas.. the car just picks up where it left off.. i mean its so fact and strong its hard to beleive the trans may be messed up but i wont upshift or downshift at all.. i can manually shift through 1,2, and drive and it still does the same thing... the trans does burn a little fluid but i check it regularly, i dont let it run low... what do you guys think? if this is something easily fixable thats great i dont really want to have to rebuild it if i dont have to...
Hi,
Also, keep your foot in it and see if it ultimately upshifts. If the modulator goes bad or loses vacuum, the trans thinks you are at wide open throttle and delays upshifts to nearly redline.
i pulled the car around to the front yard...put it in park.. took the vacuum line off the modulator, its got plenty of vacuum, reconnected the vacuum line, put the car back in drive AND NOW IT WONT MOVE!!! LOL i have to rev it pretty high just to get it to move a foot... WHAT HAPPENED???!!!
