th350 upgrade
Old Feb 26, 2009 | 12:04 PM
nathanf85's Avatar
th350 upgrade
hi everyone I have the chance to get a rebuilt th350 with a shift kit and a 3000 stall for cheap my question is do you think that stall is to big for my needes.I have a 455 with a performer intake and eldelbrock 600 carb and headers.Other than that pretty much stock.Im not trying to go to the race track I just want a bad a$$ street machine.Any input will be greatly apprecitated thanks
Old Feb 26, 2009 | 12:35 PM
tim72's Avatar
Go with a TH 400. It is much stronger than the TH350. Remember how much torque that 455 has.
Old Feb 26, 2009 | 12:50 PM
nathanf85's Avatar
I would rather have a th 400 but I can get the th350 and the stall for three hundred bucks.Sounds to good to be true but we will see I pick it up tomorrow morning.
Old Feb 26, 2009 | 02:00 PM
X 2
I've got a friend with a th350 hooked to a 455 with no problems. Just a daily driver mind you.
Old Feb 26, 2009 | 02:16 PM
citcapp's Avatar
It really depends how it was built. There are plenty of 350 trannys behind 455's and they hold up just fine. If you plan on lots of burn outs and gear banging then you had better plan on the 400 unless the 350 has been built to withstand the abuse.
Old Feb 26, 2009 | 03:40 PM
gearheads78's Avatar
car guy
3000 stall behind what? If it was another torque monster thats one thing but if it was 3000 behind a 307 it will be a lot higher on a 455.
BBO don't need a lot of converter because of the torque.
Old Feb 27, 2009 | 08:54 AM
nathanf85's Avatar
thanks everyone for the info this is the coolest site ever
Old Feb 27, 2009 | 04:28 PM
Don't buy the transmission. For $300 you can buy a shift kit and aftermarket torque converter from Summit and install it in your transmission on the weekend. Plus, this will allow you to decide exactly what shift kit and torque converter you want.
Jolly Green
Feb 13, 2008 12:33 PM
bcg88
Jan 17, 2008 11:35 AM
LMHConcepts
Jan 4, 2008 12:55 PM
bcg88
Jul 15, 2007 06:06 PM
sean000
Dec 22, 2006 06:41 PM
