crossmembers
Old Feb 11, 2009 | 10:37 AM
Charlie_brown's Avatar
crossmembers
Would i be able to mount a th400 to a stock g-body cross-member.
Old Feb 11, 2009 | 10:48 AM
dan2286's Avatar
If you have a 200-R4 trans now it will bolt up. You also need to make sure the 400 trans is a short tail.
Old Feb 11, 2009 | 11:02 AM
nope its a long tail! already planned on taking the drive shaft to the shop to get cut though. So i know its made for the 200-r4 but will it fit the th400? i also have a cut up make shift cross-member that held in my th350 will this one do if the stock one doesn't?
Old Feb 11, 2009 | 11:27 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
You will need to extend the frame, and move the stock xmember back.
OR
if you want to be ghetto about it, a 73-77 A body x member will ride inside the C channel part of the frame. You could drill some holes and put some bolts in that way, but it won't be as strong. Good enough for a daily driver, but if you're going to race it, it will most likely fail tech.
rcktdoc
Jun 25, 2014 04:45 AM
brandon reynolds
Jun 13, 2013 01:21 PM
