66 cutlass won't shift
Greetings All
I have a 1966 cutlass 330 4bbl that wont shift automatically. The problem started (I think) when I replaced the carburator. I can shift the car manually (not good). Any suggestions?
i had the smae problem with the 65 mustang my parents have. the carb had work done, then the trans started shifting funny. dunno if they ever fixed it, but someone should be in to be able to help you soon. either way, welcome to the site!
Check to see if you put the vacuum hose back on for the trans vacuum modulator. make sure it is at manifold vacuum.
Also make sure the hose is not crack or broken ans is still hook up at the trans.
Gene
Gene
hvysupreme
Feb 18, 2017 12:40 PM
Alocatelli
Dec 10, 2012 07:49 AM
