PDA
View Full Version : Transmission
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13
  1. Shift lever button sticks
  2. 371 6 pack
  3. TH350 Slip Yoke Leak
  4. Torque convertor swap
  5. Switch Pitch TH400 switch
  6. 68 Cutlass linkage
  7. Turbo 400 pump bolt leak
  8. 2004r dipstick the same as th350? G body
  9. Speedometer driven gear
  10. TH 400 stall speed question
  11. Speedometer gear, how many teeth?
  12. Any Boise Area members?
  13. 70 cutlass Supreme hard shift to 2nd gear th350
  14. 67 C/S 2Speed trans
  15. Shifter and linkage. 68 442
  16. Comp plus push in stick
  17. 4l80e recommendations
  18. Tremec TKX Selection Recommendation
  19. 200-4R id help.
  20. ST300 transmission rebuild
  21. 1955 Hydramatic slant pan.. need fill tube & dipstick
  22. Where can i find a replacement transmission?
  23. Torque converter help
  24. Lokar Shifters
  25. 1972 Cutlass Turbo 400 - a couple issues
  26. TH400 kickdown question?🤔
  27. Damper Plate chiped
  28. Shifting problems dynamic 88 -60
  29. TH350 Kickdown Cable Identification
  30. 63 F85 Transmission Rebuild
  31. Hydro matic Shifting
  32. 200-4R Trans
  33. 72 TH350 Transmission upgrade
  34. Cutlass with ratchet shifter - Pictures wanted
  35. New TREMEC TKX 5 speed
  36. TH350 Automatic Slippage and Odd Shift?
  37. Pump Seal/Converter Leak
  38. '70 Cutlass trans cooler line replacement
  39. Th350C lockup trouble
  40. Transmission replace
  41. Floor Shifter ???
  42. TKO600 for 455
  43. Wait for 200-4R or go with TH350?
  44. TH400 Metal Dust Cover
  45. 200-4r in a 67 Cutlass trans cooler lines question....
  46. Speedometer Problem
  47. No re-Shift to 3rd after Kickdown :/
  48. 72 Muncie M-20 - Back up lights - linkage bushings
  49. 200-4r pressure test strange issue
  50. 72 H/O Turbo 400 question
  51. TH350 now has 6 neutrals....
  52. TH350 Temp Gauge - Ideas
  53. ST300 leaking stream of trans fluid when car running
  54. 200r4 lockout question
  55. TH350 Leak Advice
  56. Kick down T-400 Adjistment?
  57. Turbo 400 Yoke Weep hole drip???
  58. '88 Toronado / 440 - T4 Question
  59. No love for the Jetaway?
  60. Speed cable leak
  61. When my car shifts second the tire chirps
  62. Trans lines to RAD or cooler
  63. Sp400
  64. 62 64 Oldsmobile full-size transmission slim jim transmission model 10
  65. TH 400 Gear Ratios
  66. 1972 TH350 Kickdown Cable LEAK
  67. Budget tremec swap
  68. Hydraulic clutch and master cylinder Help
  69. Best kit for 4spd pedal/linkage conversion on 70-72 Cutlass?
  70. Torque converter recommendation
  71. Best Reman 200-4Rs
  72. What are you guys running for transmissions?
  73. Th350 won't roll in neutral
  74. TH400 Long shaft under A-Body’s?
  75. TH425 starts in 2nd gear
  76. 200-4R Pump Stator Washer
  77. worst auto transmissions built.
  78. 1970 Cutlass S 350 - transmission rebuild
  79. Th425 build for motorhome
  80. 1965 f85 th400 swap
  81. M 21 question
  82. Trashed my Monster TH350, concur with mechanic?
  83. 76 Cutlass park lock system bushing
  84. Big car slim jim transmissions are they reliable?
  85. Tranny noise
  86. Black Wire w/orange Stripe
  87. Thoughts about a short term trans behind healthy torque, 2004R or TH350?
  88. TH 400 service
  89. 2004r finished!!
  90. pilot bushing or bearing
  91. 350 trans will not shift
  92. 200R4 Identification
  93. Pressure plate
  94. How much HP through a slimjim
  95. Switch pitch converter
  96. Pan Leak Question
  97. R700 Trans Bell Housing
  98. 2004r clearances
  99. 200-4R OD Hesitation
  100. Non-Lockup Torque Converter
  101. Changing st300 to th350
  102. Speedo calibration
  103. 1st TH350 Rebuild
  104. Trans TH 350 not engaging 1972 cutlass
  105. 200R4 TV cable
  106. Sticking kickdown switch
  107. Th 350 with odd governor
  108. 3 transmissions same problem
  109. TH350 with transgo holds 2nd too long
  110. Another 2004r build, dual feed
  111. TH350 Help
  112. Centerforce still Oldsmobile compatible?
  113. Transmission Issue? Rear Axle Ratio vs Speed
  114. 62 cutlass transmission alternatives
  115. Jetaway (ST300) leaking from speedo gear housing
  116. 1964 Jetaway ailing
  117. tko midshift vs rear
  118. 72 Vista Cruiser 375-THM to 200R4 conversion
  119. Pan w/ drain plug recommendations?
  120. My 72 clutch replacement begins...
  121. TH350 Leak Detection
  122. Think I've burnt my trans up..
  123. Transmission adapter plate
  124. shifter cable
  125. Shifter Rod ID
  126. Flexplate to convertor bolts: TH200-4r
  127. Installing a Dual Gate on a 70 442 from an automatic console shift need help!!!
  128. Th 400 gurus needed
  129. TH350 Questions
  130. 64 Starfire - What type of transmission fluid to use?
  131. Flywheel question —330
  132. Th350 1-2 accumulator bore slight gouge
  133. Finding a leak...
  134. 1970 Cutlass
  135. Hurst Pistol Grip Shifter - 4Speed for 2004R
  136. Transmission lines from 200r4 to radiator
  137. TH350 SPeedo Cable Seal Replacement help
  138. Needing advices
  139. Vacuum modulator line
  140. 2004R Build Questions
  141. Torque converter Id?
  142. engine swap 1983 98 royal
  143. Speedometer gear seal
  144. 330 to 425 swap switch pitch question
  145. 4L80E in a 71 Cutlass
  146. The Right Torque Converter for 350/TH350
  147. Torque Converter Recommendations?
  148. 1965 turbo 400 switch pitch stuck in high stall speed I believe but he’s to old cars.
  149. 1976 Cutlass Transmission Problem
  150. Monster 200 4r
  151. TH400 slipping out of 3rd
  152. 2004r weird shifting
  153. Auto Trans ???
  154. Gear box options
  155. 67 conv cutlass cross member
  156. New clutch for a 68 442 - opinions
  157. Th 400
  158. shiftwork sc231 69 cutlass 2004r
  159. Selecting Drive
  160. Inappropriate Shifting
  161. 1987 Ciera TH125c to 4T40?
  162. Column shifter rattle
  163. 1968 Hurst/Olds OW VS. OG 442 transmission
  164. 63 f85 with th350?
  165. 200-4R parts questions
  166. 200 r4 transmission identification????
  167. 65 Cutlass 442 high speed vibration problems
  168. 5-speed
  169. Hughes GM-20 or GM-25
  170. Th 400 ID help
  171. 2004R Cooler Lines
  172. Th400 not locking into gear
  173. 1970 olds SX kickdown switch
  174. Picked up a used 2004R
  175. 1968 Jetaway Kickdown Switch Replacement
  176. wire harness for TH 400 Kickdown
  177. Th400 help
  178. New or rebuilt th350
  179. Novice Advice on 2004R rebuild
  180. 200-r4 swap
  181. Wiring from the ST 300 transmission...
  182. TH400 Driven Gear
  183. Clutch size
  184. Used 200-4R
  185. '71 Cutlass TH350 Kickdown Q's
  186. 62 Starfire Slim Jim tranny pressure ports?
  187. T-50 swap
  188. 67 C/S 330 2 speed trans swap
  189. BOP TH400 with short 4" tailshaft
  190. Switch Pitch convertor
  191. How much transmission fluid when pulling the pan on 2 Speed Jetaway? ST300
  192. Opinions on Jetaway tranny
  193. Tranny rebuild gone wrong?
  194. 2004R Performance Tips
  195. Jetaway to 200-4r swap, crossmember doesn't fit
  196. 200-4R transmission question
  197. TH350 Inspection Cover Bolt Size?
  198. Clutch rod length
  199. 700R4 conversion to 70 olds 455?
  200. 1965 4 speed shifter
  201. 72 Cutlass, TH350 to TH400 Question
  202. Column to floor shift swap
  203. 4spd to 2004r 69 cutlass
  204. Torque Converter and RPM
  205. Trans won't shift
  206. Torque Converter Vibration/ Rotation
  207. Engine swap - now won't move
  208. 67 Cutlass - 2 speed ST300 pitch/switch adjustment
  209. transmission fluid for 1950 hydramatic
  210. TH400 won’t shift into third
  211. Muncie ID ?
  212. 2004r help
  213. How do i adjust shifter...
  214. 72 cutlass t350 overhearing
  215. Doug Nash 5 speed
  216. TH350 Fluid Overfilled
  217. Changing the transmission filter 1970 Oldsmobile Rallye 350
  218. Pan gasket
  219. 6 speed swap?
  220. 4 Speed Clutch Pedal Help
  221. Will a chevy 350 automatic tranny fit in an 86 Grand Prix?
  222. Speedometer gear delete th350
  223. speedometer gear housing for a 22 teeth driven gear
  224. Converter stall question
  225. Tired Hydramatic
  226. advice 394 olds flywheel
  227. M21 Hurst shifter rebuilder
  228. Stock Hurst 4-speed - sloppy/vauge
  229. 2004r Lock-up
  230. 200 4R trans won’t shift out of first gear
  231. 65' Cutlass with a TH350
  232. TH 400 overdrive
  233. Trans not shifting firm
  234. Overdrive Transmission Into '76 Cutlass?
  235. Clutch recommendations
  236. TH350 kickdown function question
  237. Trans overfilled?
  238. Bop trans to a 394?
  239. ST300 to TH350 SWAP ?
  240. 1959 88 Dynamic Holiday Sports Sedan Transmission
  241. Brand new tranny slipping /not shifting
  242. Clutch and Pressure Plate Rebuild Service
  243. Jetaway to 700R4 conversion
  244. turbo 400 yoke selection
  245. TH 350C to 350?
  246. Seal removal Tool
  247. 1969 Cutlass 4 speed transmission
  248. 64 Dynamic 88 transmission fluid
  249. Just added TH400 - speedometer is off
  250. Th 400 auto trans code "OD" detailing
