Hughes GM-20 or GM-25
Old Mar 1, 2020 | 07:04 AM
coppertopgmc's Avatar
I’m looking at getting the converter for my 71 Cutlass, my engine is a 350 with 7 heads and flat top pistons, camshaft is comp XE268H and recommends 1800+ stall, I have 3.73 gears in the car but am considering changing to 3.4-3.55 for better cruising rpm’s , just wondering if I’m safe going with the GM-20 or do I need to go to the GM-25. Not building a race car just a street/cruiser.
Old Mar 1, 2020 | 07:25 AM
coppercutlass's Avatar
Chevy budget Olds powered
The 2500 will be fine. You won't start getting that slipping clutch feel from the torque converter until you get into the 3000 stall range.
Old Mar 1, 2020 | 07:46 AM
Thanks I knew I would get the answer I needed on this forum.
Old Mar 1, 2020 | 08:15 AM
I looked up the cam specs and that one is 224° / 230° @ .050" lift, so yeah, I'd go with the 2500 RPM converter. Same one I have and I think you will like it.
71OldscutlassS
May 12, 2020 05:11 PM
Chuck Cole
Mar 15, 2019 05:00 AM
rkk69olds
Jan 12, 2012 07:45 PM
import extermination
Oct 10, 2011 03:55 AM
Wasted
Jun 14, 2009 04:54 PM
