64 Dynamic 88 transmission fluid
Old July 22nd, 2019, 08:17 AM
Nikojoe's Avatar
I was just about to add some dextron atf, but I though I would ask first.
Will the 64 stock Dynamic 88 transmission accept dextron III fluid?
Nikojoe is offline
Old July 22nd, 2019, 10:20 AM
jaunty75's Avatar
You have no choice. The only T-fluid you can find for these cars nowadays is called "Dex/Merc," and if you read the fine print on the container, it says that it is for use with GM cars made before 2006. In any event, put this in your transmission, and you'll be fine. It's called "Dex/Merc" regardless of brand.
jaunty75 is offline
Old July 22nd, 2019, 11:36 AM
Phantom Phixer
Charlie Jones's Avatar
Dex/Merc fluid is certainly the type to use .
But , if you don't know when ( or even IF ) the fluid has been changed . Then it would be a good idea to change the fluid and install a new filter .
Filters and pan gaskets can be had from FATSCO ;
https://www.fatsco.net/store.html#!/...=0&sort=normal
Charlie Jones is offline
Old July 22nd, 2019, 02:59 PM
Nikojoe's Avatar
Confirmed. Thank you for the replies.
Nikojoe is offline
Old May 25th, 2020, 10:08 PM
Killian_Mörder's Avatar
...pan gaskets can be had from FATSCO...
That's an interesting site. Strange that it's not readilly available, when looking up parts through the usual search engines. The brand I'm working on isn't listed and I don't know if they'll ship the pan gasket to Germany which resembles one from a transmission of another brand. In which case, I'll either go out and get a sheet of cork or I'll do what another forum recommended which was to go goop:
https://www.permatex.com/products/ga...-gasket-maker/
The engine oilpan left the factory siliconed. The manual, however, says to use a gasket on the transmission pan. If they didn't want it glued on, they must have had a good reason for telling everyone that
Killian_Mörder is offline
radioburningchrome
March 22nd, 2018 10:18 AM
btw
Brakes/Hydraulic Systems
October 6th, 2016 10:21 AM
jpc647
June 24th, 2014 10:11 AM
ollerich29
September 13th, 2013 10:59 AM
AZ455
June 25th, 2011 06:08 AM
Quick Reply: 64 Dynamic 88 transmission fluid
