Vacuum modulator line
Old May 11, 2020 | 07:00 AM
NorthBay72supreme's Avatar
When cutting out a rusted floor plan, I accidentally cut the vacuum modulator line that runs to the tranny. Found a replacement on Ebay and replaced it. Now, although the column mounted gearshift moves and appears to move normally, I can't get out of park. I should mention the entire interior including all wiring harnesses and the dash is ripped apart, so I can't start it currently.
72 cutlass, rocket 350, th-350
Thanks guys
Old May 11, 2020 | 09:02 AM
The vac modulator line has nothing to do with shifting in and out of PARK, so what else did you cut or disconnect in the process?
Old May 11, 2020 | 10:19 AM
How much floorboard did you cut out? Sounds as if you may have disturbed the backdrive linkage that runs form the drivers side of the transmission to the collar on the steering column.
Old May 11, 2020 | 11:44 AM
I am replacing guages next, and disconnected, well, everything.
Old May 11, 2020 | 11:46 AM
I just took out the front passenger side. The vacuum modulator line was very close to the floorboard. I don't see anything else affected.
1972_NJ_Supreme
Oct 13, 2019 03:33 PM
oldsguybry
22
Jan 8, 2018 10:44 PM
Homestar
Apr 3, 2011 05:54 PM
54olds
Aug 7, 2008 12:20 AM
68ragtop
Jun 29, 2008 06:43 AM
