Vacuum modulator line
Old May 11th, 2020, 07:00 AM
NorthBay72supreme's Avatar
When cutting out a rusted floor plan, I accidentally cut the vacuum modulator line that runs to the tranny. Found a replacement on Ebay and replaced it. Now, although the column mounted gearshift moves and appears to move normally, I can't get out of park. I should mention the entire interior including all wiring harnesses and the dash is ripped apart, so I can't start it currently.
72 cutlass, rocket 350, th-350
Thanks guys
NorthBay72supreme is offline
Old May 11th, 2020, 09:02 AM
The vac modulator line has nothing to do with shifting in and out of PARK, so what else did you cut or disconnect in the process?
joe_padavano is online now
Old May 11th, 2020, 10:19 AM
How much floorboard did you cut out? Sounds as if you may have disturbed the backdrive linkage that runs form the drivers side of the transmission to the collar on the steering column.
Fun71 is offline
Old May 11th, 2020, 11:44 AM
I am replacing guages next, and disconnected, well, everything.
Old May 11th, 2020, 11:46 AM
I just took out the front passenger side. The vacuum modulator line was very close to the floorboard. I don't see anything else affected.
1972_NJ_Supreme
October 13th, 2019 03:33 PM
oldsguybry
22
January 8th, 2018 10:44 PM
Homestar
April 3rd, 2011 05:54 PM
54olds
August 7th, 2008 12:20 AM
68ragtop
June 29th, 2008 06:43 AM
Quick Reply: Vacuum modulator line
