Another 2004r build, dual feed
I've already done the Dual feed with the transgo kit, before the overhaul, where you have to drill the case.
Now that I'm doing the overhaul C K also has a dual feed where you have to remove a seal or seals.
My question is; do I do both where I remove a seal or do I leave it as is with the transgo kit and not worry about the seal?
Since you modified the passages under the valve body, you need to leave that as-is and do NOT do CK's internal mods. Re-install all the seals and the stock center support bolts.
Otherwise, you'd need to get a new case that hasn't been modified or re-build the wall that was drilled out. Doing both modifications might lead to a situation where reverse and third are engaged at the same time.
I’m just finishing up CK’s street-strip build, and they are now using a valve body/spacer plate mod to do the dual feed. Cris told me not/not to do the oil ring delete/oil feed plug mod per his manual - at least for this kit.
